wifi adapter wont Sync with RA client
Posted: Sat Jun 15, 2013 4:51 pm
by tomek77pl
Hi
I recently purchased a wifi expansion and I got everything to work with the portal and my iphone but I cannot figure out how to connect the reef angel client suite to my wifi adapter. Am I missing a something in my code? because everything in the RA client settings is set correctly. thank you for your help :)
Here is my code:
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port5Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardHeater( Port1,773,778 );
ReefAngel.DosingPumpRepeat( Port6,0,50,15 );
ReefAngel.StandardLights( Port7,23,0,10,0 );
ReefAngel.SingleATO( true,Port8,10,0 );
ReefAngel.Portal( "tomek77pl" );
I also get this error message :
*****6/15/2013 8:23:34 PM*****
Message:
Inside WifiSend:
Unable to connect to the remote server
StackTrace:
at System.Net.WebClient.DownloadDataInternal(Uri address, WebRequest& request)
at System.Net.WebClient.DownloadString(Uri address)
at System.Net.WebClient.DownloadString(String address)
at ReefAngelWCFListener.ReefAngelListener.WifiSend()
Re: wifi adapter wont Sync with RA client
Posted: Sat Jun 15, 2013 7:34 pm
Your code looks fine.
Make sure that you have it set to connect over wifi and that you have the correct url.
Posted: Sat Jun 15, 2013 7:58 pm
by tomek77pl
The client mentions that it can not complete a web-request call to the wifi adapter. what could cause this? I have set all the right addresses to the portal. but when I access my portal it says that my connection status: Unreachable address. is that normal?
Posted: Sun Jun 16, 2013 5:22 pm
by dbmet
Is your port forwarding turned on in your router for port 2000?
Posted: Tue Jun 18, 2013 2:34 pm
by tomek77pl
Got it to work, it was the port forwarding, thank you so much :)
Posted: Tue Jun 18, 2013 3:40 pm
by dbmet
Great!!
Posted: Sat Jun 22, 2013 10:01 am
by tomek77pl
I still get an error message from the wifi Icon that says Could not complete the web request call to wifi adapter & when I set up my notifications for low PH I get email and texts every hr saying my ph is 6.84 when on the Reef Client, Portal and on the controller it self I have my ph around 7.89. I have calibrated the probe yesterday as well.
