[youtube]http://www.youtube.com/watch?v=nJ71dvUF-Zs[/youtube]
The cable is inserted correctly at both ends. If I leave it unplugged the head unit is fine forever.
Are there any troubleshooting steps I can take? Before the head unit goes into that infinite loop the wifi attachment does light up green and works via the portal/android phone, very briefly. Then the wifi flashes an orange LED and goes into the loop in the video.
my current code
#define Heater 1
#define Return 2
#define Skimmer 3
#define Vortech1 5
#define Vortech2 6
#define ATO 7
byte vtechmode;
ReefAngel.FeedingModePorts = Port2Bit;
ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port7Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port5 );
// Hardcode calibrations
ReefAngel.PHMin=576; // PH7.0
ReefAngel.PHMax=842; // PH10.0
ReefAngel.SalMax=3000; // 35ppt
ReefAngel.StandardHeater( Port1,796,802 );
StandardHeater2( Port3,760,770 );
ReefAngel.WaterLevelATO( Port7,120,50,52 ); // If water level less than 52, turn on auto top off relay; else, keep it off
ReefAngel.PWM.SetChannel( 0,PWMSlope(21,30,8,0,15,31,10,15) );
ReefAngel.PWM.Channel1PWMSlope();
ReefAngel.PWM.Channel2PWMSlope();
ReefAngel.PWM.Channel3PWMSlope();
ReefAngel.PWM.Channel4PWMSlope();
// ReefAngel.SingleATOLow(Port2);
if ( ReefAngel.HighATO.IsActive())
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.Off(Port2);
if (hour() >=8 && hour() < 21)
if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
ReefAngel.RF.UseMemory=true;
ReefAngel.Relay.Off(Port8);
ReefAngel.RF.UseMemory=false;
ReefAngel.Relay.On(Port8);
ReefAngel.Portal( "bencollinz" );
char text[7];
ReefAngel.LCD.DrawDate( 6, 2 );
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
for (byte Left=93; Left < 133; Left+=10)
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, Left, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, Left, "|");
ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
ReefAngel.LCD.DrawText(0,255,10,30,"Temp");
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,50,30,"Temp2");
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 50, 40, text, Num8x8);
ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
ReefAngel.LCD.DrawOutletBox( 12, 77, TempRelay );
// water level
ReefAngel.LCD.DrawText(0,255,8,68,"WL:");
ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 40, 68, ReefAngel.WaterLevel.GetLevel() );
void StandardHeater2(byte HeaterRelay, int LowTemp, int HighTemp)
if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
Also, I did have a power outage that ended up frying 3 of my other expansions which have since been replaced. I'm really hoping this isn't the same case.
