wizard + client suite 3 lighting problem
Posted: Wed Jun 19, 2013 5:31 pm
by grafxalien
I recently updated everything on my reefangel and used the wizard to create all of my code. I used the the " internal memory" setting. I am trying to use client suite 3 to change the PWM on my lights. When I change the % and click ok it changes is for about 5 seconds on the application itself and then reverts back to the old setting and the lighting never actually changes. Ideas?
Re: wizard + client suite 3 lighting problem
Posted: Wed Jun 19, 2013 5:53 pm
You must override on one of the ports you have assigned as lights on.
Posted: Wed Jun 19, 2013 5:57 pm
by grafxalien
As in override to keep the port on all the time? Also, what is the APWM% and DPWM% in the memory section of the client suite controlling? The numbers in there don't correlate to anything I have set.
Posted: Wed Jun 19, 2013 6:12 pm
Yes, if you override the port on, the pwm channels will be overridden too, but will return to your regular values when you remove the override.
I don't think the client can set parabola or slope settings.
