new version issue
Posted: Wed Jun 19, 2013 8:11 pm
by jjdezek
I downloaded the latest version and redid my wizard and coding for my RA went into the portal to do the wp40 set up and no matter what i do it stay at 20 on both. whats up with that?
Re: new version issue
Posted: Wed Jun 19, 2013 10:28 pm
Can you post your code?
Posted: Thu Jun 20, 2013 5:23 am
by jjdezek
I had to put the codes back in the custom area to get it to work. I was told with the new version you could toggle between wave modes in the portal. is this possible now?
#define NUMBERS_8x16
ReefAngel.LCD.DrawDate(6, 112);
ReefAngel.LCD.DrawText(COLOR_INDIGO, COLOR_WHITE,25,5, "Jeremy's Reef");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
    ReefAngel.WaterChangePorts = Port1Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
     ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardATO( Port1,60 );
    ReefAngel.StandardLights( Port3,18,0,10,0 );
    ReefAngel.WavemakerRandom( Port5,30,100 );
    ReefAngel.WavemakerRandom( Port6,30,100 );
    ReefAngel.StandardHeater( Port7,752,755 );
     if (hour()>=8 && hour()<12)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(100,20,true) ); // ReefCrest at 100% +/- 20% on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(100,20,false) ); // ReefCrest at 100% +/- 20% on anti-sync mode
else if (hour()>=12 && hour()<18)
  ReefAngel.PWM.SetDaylight( ShortPulseMode(0,100,200,true) ); // Short pulse at 100% with 200ms pulse on sync mode
  ReefAngel.PWM.SetActinic( ShortPulseMode(0,100,200,false) ); // Short pulse at 100% with 200ms pulse on anti-sync mode
  ReefAngel.PWM.SetDaylight( LongPulseMode(0,100,10,true) ); // Long pulse at 100% with 10s pulse on sync mode
  ReefAngel.PWM.SetActinic( LongPulseMode(0,100,10,false) ); // Long pulse at 6100% with 10s pulse on anti-sync mode
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
   ReefAngel.PWM.SetActinic(0);
   ReefAngel.PWM.SetDaylight(0);
    ReefAngel.Portal( "jjdezek" );
void DrawParamsa(int x, int y){
char buf[16];
  ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+40,y+10,"WP40L:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+78, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+40,y+20,"WP40R:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+78, y+20,1);
void DrawParams(int x, int y) {
  char buf[16];
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+5,y,"Temp:");
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+80, y, "PH:");
  // Temp and PH
  y+=10;
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+80, y, buf, Num8x16);
  y+=5;
void DrawStatus(int x, int y) {
  int t=x;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"High",Font8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,y,"Low",Font8x16);
    ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_GREEN);
  } else {
    ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_RED);
  if (ReefAngel.LowATO.IsActive()) {
    ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_GREEN);
  } else {
    ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_RED);
Posted: Thu Jun 20, 2013 7:37 am
Yes, but you need to generate a code with the wizard and make sure you check mark DC Pump on the attachment list.
Posted: Thu Jun 20, 2013 7:58 am
by jjdezek
ok found it. thanks. i was looking under the dimming portion for a jeabo option. its earlier in the wizard.
Posted: Thu Jun 20, 2013 8:01 am
by jjdezek
what is the duration under the portal do?
Posted: Thu Jun 20, 2013 8:03 am
It's the length of the cycles for short and long pulse.
Posted: Thu Jun 20, 2013 8:10 am
by jjdezek
Ok I set it up for reefcrest at 100% and duration of 9 and my power head is not working now
Posted: Thu Jun 20, 2013 8:33 am
Can you post the code?
Posted: Thu Jun 20, 2013 9:06 am
by jjdezek
its running now but im not able to switch from one mode to another in the portal. it just stays in the reefcrest mode. also i set it at 100% yet it will go up to 120% on the display and in the portal. is it really running that high?
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
    ReefAngel.Wavemaker( Port5,60 );
    ReefAngel.Wavemaker( Port6,60 );
    ReefAngel.StandardHeater( Port7,751,761 );
    ReefAngel.DCPump.SetMode( ReefCrest,100,10 );
    ReefAngel.DCPump.DaylightChannel = AntiSync;
    ReefAngel.DCPump.ExpansionChannel[0] = None;
char buf[16];
  char buf[16];
  // Temp and PH
  y+=10;
  y+=5;
  int t=x;
  } else {
  } else {
Posted: Thu Jun 20, 2013 9:10 am
Your code is hard coding the mode and is disabling memory.
Take out those two lines...the one saying UseMemory=false; and the one after setting it to ReefCrestMode.
Posted: Thu Jun 20, 2013 9:16 am
by jjdezek
ok deleted the usememory=false but cant find the other one.
Posted: Thu Jun 20, 2013 9:20 am
by jjdezek
are you talking about this part of the code?
Posted: Thu Jun 20, 2013 9:46 am
Yes.
Posted: Thu Jun 20, 2013 9:56 am
by jjdezek
ok done but it still seems like its not working correctly. i can switch it between reefcrest and tidal swell but cant get it to take nutrient export or a few others. its like sometimes it works and other times it wont.
Posted: Thu Jun 20, 2013 10:19 am
by jjdezek
It works from my phone computer is to slow to work I guess
Posted: Wed Jun 26, 2013 6:34 am
by Poiromaniax
just on the duration note - will the duration affect Vortech pump modes as well? Say if i want to run the default Vortech ReefCrest mode, do i make duration 0 or leave it as 10?
Posted: Wed Jun 26, 2013 6:53 am
Duration is not used by reefcrest
Posted: Thu Jun 27, 2013 4:24 am
by Poiromaniax
