Bad Analog Dimming Module ?
Posted: Thu Jun 20, 2013 12:06 pm
I think I may have a bad dimming module in my relay box. Everything was fine until last night and I noticed that my daytime LEDs were not dimming as evening went on. The Blues were dimming fine. Tried resetting (powering off) the controller a couple of times. When the timer finally turned off the power to all the LED's I checked the voltage on the daytime pins coming out of the the relay box and it was 7.32 volts. Zero volts on the Anitics side.
Anyone have a suggestion ? Do I need a replacement ?
I should add that the Reef Client was showing that the dimmers were at zero percent, so they both should have been off.
Mike
Mike
