Weird PH probe issue
Posted: Fri Jun 21, 2013 8:55 am
I searched the forum and couldn't really find anything regarding this problem. My PH probe appears to be working fine for the most part, however I am getting dips down to 6.32. The dips appear to be 6.32 every time but they occur at random times in the day. The PH probe is relatively close to a Tunze pump in ReefCrest mode, would this cause the drops in PH when it changes speed?
Also this probe is fairly new and has only been installed for a couple days. I calibrated it using PH7 and PH10 solution, letting it sit in each solution until the numbers didn't fluctuate for at least 10 minutes.
Edit: The ReeAngel Client v3.0 shows these dips however the portal doesn't appear to show them.
