SprintF / DrawText problem - Help :(
Posted: Fri Jun 21, 2013 5:41 pm
by Smotz
Hi!
This for some reason stopped working:
char buf[16];
sprintf(buf,"RC %d% +/-%d%",wpWavStr,wpWavOff);
ReefAngel.LCD.DrawText(0,255,15,52,buf);
but this works fine (meaning my wpWavStr & wpWavOff variables are working):
ReefAngel.LCD.DrawText (0,255,15,52,wpWavStr);
ReefAngel.LCD.DrawText (0,255,35,52,"+/-");
ReefAngel.LCD.DrawText (0,255,55,52,wpWavOff);
Can anyone show me where I've gone wrong?
Re: SprintF / DrawText problem - Help :(
Posted: Fri Jun 21, 2013 5:50 pm
Make sure you got a large enough array.
Posted: Fri Jun 21, 2013 5:56 pm
by Smotz
rimai wrote:Make sure you got a large enough array.
Oh, my array is large, buddy! (just kidding, had to)
Sorry, I am new to the sprintf function.
I did change char buf[16]; to char buf[32]; but it didn't help.
To be specific - it is displaying "RC 55" and not the rest of the line.
Posted: Fri Jun 21, 2013 6:23 pm
LOL
Can you post the entire code?
Posted: Fri Jun 21, 2013 6:29 pm
by Smotz
rimai wrote:Can you post the entire code?
sure.
I'm having more problems, Roberto. Sorry, I'm a n00b.
My wpMode is incorrect. It's 9:28 here, I should be on mode 2 but it is in mode 3.
////  Port 1			Heater
////  Port 2			ATO pump
////  Port 3			Reactor Pump
////  Port 4			Protien Skimmer
////  Port 5			Return Pump
////  Port 6			Wavemaker
////  Port 7                    UV Sterilizer
////  Port 8                    Fuge Light
////  Always on - Lights & Salinity Module
#define Heater Port1
#define Topoff Port2
#define Reactor Port3
#define Skimmer Port4
#define Return Port5
#define Wave Port6
#define UVlight Port7
#define Fugelight Port8
#define FugelightBit   1<<7
#define UVlightBit   1<<6
#define WaveBit   1<<5
#define ReturnBit   1<<4
#define SkimmerBit   1<<3
#define ReactorBit   1<<2
#define TopoffBit   1<<1
#define HeaterBit   1<<0
byte wpMode;
byte wpWavStr;
byte wpWavOff;
  ReefAngel.FeedingModePorts = TopoffBit | ReactorBit | SkimmerBit | ReturnBit | UVlightBit;
  ReefAngel.WaterChangePorts = HeaterBit | TopoffBit | ReactorBit | SkimmerBit | ReturnBit | WaveBit | UVlightBit;
  ReefAngel.LightsOnPorts = FugelightBit;
  ReefAngel.OverheatShutoffPorts = HeaterBit | TopoffBit | ReactorBit | SkimmerBit | ReturnBit | WaveBit | UVlightBit;
  // Use T1 (SUMP) probe as temperature and overheat functions
  ReefAngel.Relay.On( Return );
  ReefAngel.Relay.On( Reactor );
  ReefAngel.Relay.On( Wave );
  ReefAngel.StandardHeater( Heater );
  ReefAngel.StandardATO( Topoff );
  ReefAngel.MoonLights( Fugelight );
  ReefAngel.LCD.DrawText(0,255,20,80,"Joe's Reef Tank");
  ReefAngel.Relay.DelayedOn(Skimmer,2);
  ReefAngel.Relay.DelayedOn(UVlight,1);
  ReefAngel.DCPump.FeedingSpeed=30;
if (ReefAngel.DCPump.Mode==Custom) ReefAngel.DCPump.UseMemory = false;
else ReefAngel.DCPump.UseMemory = true;
  // Custom Wave Routine
  if (ReefAngel.DCPump.Mode==Custom)    {
    // set the wpMode
    if ( (hour() >= 5) && (hour() < 8) ) wpMode=1;       // from 5am - 8am
    if ( (hour() >= 8) && (hour() < 11) ) wpMode=2;      // from 8am - 11am
    if ( (hour() >= 11) && (hour() < 14) ) wpMode=3;     // from 11a - 2pm
    if ( (hour() >= 14) && (hour() < 17) ) wpMode=2;     // from 2pm - 5pm
    if ( (hour() >= 17) && (hour() < 20) ) wpMode=1;     // from 5pm - 8pm
    if ( (hour() >= 20) && (hour() < 23) ) wpMode=2;     // from 8pm - 11p
    if ( (hour() >= 23) && (hour() < 2) ) wpMode=3;      // from 11pm - 2am
    if ( (hour() >= 2) && (hour() < 5) ) wpMode=2;       // from 2am - 5am
    // Set Wave Str
    if (wpMode=1) wpWavStr=45;
    if (wpMode=2) wpWavStr=50;
    if (wpMode=3) wpWavStr=55;
     //Set the Wave OffSet
    wpWavOff=12;
    if (ReefAngel.DisplayedMenu==FEEDING_MODE) wpWavStr=30; wpWavOff=0;
    ReefAngel.DCPump.SetMode( ReefCrest,wpWavStr,wpWavOff );
    //char buf[16];
    //sprintf(buf,"RC %d% +/-%d%",wpWavStr,wpWavOff);
    //ReefAngel.LCD.DrawText(0,255,15,52,buf);
  // end Custom Wave Routine
  //  Only turn on UV Sterilizer between 11pm and 5am
  if ( (hour() >= 5) && (hour() < 23) )  // from 5a - 11p
  ReefAngel.Relay.Off(UVlight);
  else ReefAngel.Relay.On(UVlight);
  ReefAngel.Portal( "Smotz" );
  // Parameters
  // Salinity
  ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
  ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
  // Main Relay Box
  // Date and Time
Posted: Fri Jun 21, 2013 6:38 pm
Your code says mode 2:
Posted: Fri Jun 21, 2013 6:51 pm
I didn't know why either, but google is your friend :)
https://www.allegro.cc/forums/thread/591765
The % is indicator of a string input element, so you must tell sprint that you want the % sign.
    sprintf(buf,"RC %d%% +/- %d%%",wpWavStr,wpWavOff);
Posted: Fri Jun 21, 2013 6:56 pm
by Smotz
rimai wrote:Your code says mode 2:
yes but mode 2 my wpWavStr should be 50 but the display out put it showing its 55
I added a wpMode=1; before the if wpmode statements but it is still saying its mode 3. Huh.
    ReefAngel.LCD.DrawText (0,255,15,80,wpMode);
    wpWavOff=12;
    //if (ReefAngel.DisplayedMenu==FEEDING_MODE) wpWavStr=30; wpWavOff=0;
by Smotz
rimai wrote:I didn't know why either, but google is your friend :)
Nice. That worked. Thank you - i did google but I think I just didn't understand.
Posted: Fri Jun 21, 2013 7:00 pm
This is not a comparison. It's an assignment:
It should be like this:
    if (wpMode==1) wpWavStr=45;
    if (wpMode==2) wpWavStr=50;
    if (wpMode==3) wpWavStr=55;
Posted: Fri Jun 21, 2013 7:04 pm
by Smotz
rimai wrote:This is not a comparison. It's an assignment:
Holy Crap! That did it - you fixed everything. Again, Thank you.
