Can't upload anything
Posted: Sat Jun 22, 2013 7:54 pm
by Blawson
I have had my RA+ for a year and I am trying to update my code. I keep getting errors everytime i try to upload anything:
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 19,040 bytes (of a 258,048 byte maximum)
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM4 -b115200 -D -Uflash:w:C:\Users\Home\AppData\Local\Temp\build3790747732963479285.tmp\InitialInternalMemory.cpp.hex:i
System wide configuration file is "C:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM4
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
The RA reboots during the upload and then I get the error.
Help please...
Re: Can't upload anything
Posted: Sat Jun 22, 2013 8:26 pm
by cosmith71
Black wire on the ttl cable all the way to the right? No empty pins on the right side?
Sent from my HTC One X using Tapatalk 4 Beta
Posted: Sat Jun 22, 2013 8:30 pm
by Blawson
yes. I am going through uninstall and reinstall right now. cable is plugged in correctly
Posted: Sat Jun 22, 2013 8:38 pm
by Blawson
That did not work. Same error.
Posted: Sat Jun 22, 2013 10:28 pm
by Blawson
OK - I changed from RA+ to Ra with bootloader and it worked... Go Figure.
Now my dimming module is not working... It is on - reading the manual it says I need to upload the PMW code - but isnt that already in the Wizard when I put that together?
Posted: Sat Jun 22, 2013 11:04 pm
by Blawson
and before anyone asks... Here's the code:
ReefAngel.FeedingModePorts = Port4Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.DosingPumpRepeat( Port1,0,60,10 );
ReefAngel.DosingPumpRepeat( Port2,0,60,10 );
ReefAngel.StandardLights( Port3,9,30,22,30 );
ReefAngel.Relay.DelayedOn( Port4,10 );
ReefAngel.StandardHeater( Port5,795,805 );
ReefAngel.Relay.Set( Port8, !ReefAngel.Relay.Status( Port3 ) );
ReefAngel.PWM.SetChannel( 0, PWMSlope(10,0,22,0,10,50,120,10) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(10,30,21,30,0,40,120,0) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(10,30,21,30,0,30,120,0) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(10,30,21,30,0,30,120,0) );
ReefAngel.Portal( "blawson" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Posted: Sun Jun 23, 2013 5:36 am
by cosmith71
When you say not working, how do you mean? Values don't change? Lights don't come on?
Posted: Sun Jun 23, 2013 7:06 am
by Blawson
Lights all come on. Values change on the controller and portal but change in intensity from the lights.
Posted: Sun Jun 23, 2013 9:07 am
Was this working before the update?
Posted: Sun Jun 23, 2013 9:42 am
by Blawson
I just added the dimming module. The RA was working fine before that. I had an AI running and it dimmed one but that was just from the head unit.
I should probably clarify. I originally bought the RA PMW unit a little over a year ago. I upgraded to the RA plus after that. I Just bought and added the dimming module (PMW) and built a new led array for it.
I got the uploading issue fixed and now have the wizard code uploaded. All lights come on but do not dim. The dimming shows on the screen and the portal. I did the internal memory so I can adjust without a new upload.
I checked and double checked to make sure all the cables were plugged in correctly.
Posted: Sun Jun 23, 2013 9:55 am
Can you check the output voltage on the dimming module without your drivers?
Sent from my SPH-L710 using Tapatalk 4 Beta
Posted: Sun Jun 23, 2013 9:58 am
by Blawson
I can but not sure how. Would I just use a multi meter?
Posted: Sun Jun 23, 2013 10:01 am
yes
Posted: Sun Jun 23, 2013 10:02 am
by Blawson
K. I will check it out and post back.
Posted: Sun Jun 23, 2013 10:36 pm
by Blawson
OK - I have to pick up a multi meter (didnt have time today)
In the meantime, I put code in to use the dimming ports on the original box but the problem is that the driver I have only uses 1 wire for dimming... The port has a + and -.
Any suggestions on wiring that puppy? Can't find anything on it.
Posted: Mon Jun 24, 2013 12:24 am
by Blawson
I got it! Wiring issue - dimming expansion seems to be working. I will get it all wired back up and let you know.
