how to revert back to older librarys?
Posted: Sun Jun 23, 2013 10:25 pm
Trying to upload new code, and keep getting sketch too big error. Tried older code that loaded fine, still getting error only difference is new librarys. So.. how do i go back? ive already downloaded the old librarys.. I put them in the reefangel folder, but it still does not recognize them...
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Custom Main Screen
Dimming Expansion Module
Simple Menu
Binary sketch size: 32,556 bytes (of a 32,256 byte maximum)
processing.app.debug.RunnerException: Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
at processing.app.Sketch.size(Sketch.java:1844)
at processing.app.Sketch.build(Sketch.java:1775)
at processing.app.Sketch.build(Sketch.java:1750)
at processing.app.Editor$DefaultRunHandler.run(Editor.java:1867)
at java.lang.Thread.run(Thread.java:619)
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
ReefAngel.StandardHeater( Port1 );
ReefAngel.DayLights( Port2 );
ReefAngel.StandardFan( Port3 );
ReefAngel.DayLights( Port4 );
ReefAngel.DayLights( Port6 );
ReefAngel.DosingPumpRepeat1( Port7 );
ReefAngel.DosingPumpRepeat2( Port8 );
ReefAngel.PWM.Channel0PWMSlope();
ReefAngel.Portal( "pandimus" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Custom Main Screen
Simple Menu
