Relay Expansion and relay box.
If I get the Relay Expansion and relay box. do the dimming ports on the relay box work?
Re: Relay Expansion and relay box.
Nope.
Sent from my HTC One X using Tapatalk 4 Beta
Nor does the expansion bus USB port.
And for the record the ports work.. but the signal isn't carry from the expansion module... so if you let's say had a PWM relay box as your main and you wanted analog dimming ports, you could buy the analog expansion module and swap the relay boxes around.
