My temp probe seems to keep sticking. Not sure if the whole system is still operational when it sticks, but it resets when I reboot the head unit. The question I have is, is it possible to build a timed reset into the code? To reset the controller at specific times during the day.
Second question, is there a way to run the controller without the transfer cable being plugged in the while time. It seems that when I unplug the cable the screen gets all distorted.
Two questions - temp probe and transfer cable
Re: Two questions - temp probe and transfer cable
Can you check which gen screen you have?
http://forum.reefangel.com/viewtopic.php?f=2&t=3111
It's gen 2. Thanks, ill read trough the linked forum for info.rimai wrote:Can you check which gen screen you have?
