DC Pump vs. PWM Daylight
Posted: Sat Jun 29, 2013 11:43 am
by clw143
What is the different between doing this:
ReefAngel.DCPump.SetMode( TidalSwell,60,10 );
and this:
ReefAngel.PWM.SetDaylight( TidalSwellMode(60,true) );
Re: DC Pump vs. PWM Daylight
Posted: Sat Jun 29, 2013 4:43 pm
The first will use more memory...otherwise as written they are the same.
Take out the set mode to tidalswell in the first and set usememory to true and it will read the params from the portal allowing you to change it..
Thats the advantage of the first..
Posted: Sat Jun 29, 2013 5:25 pm
They are both the same.
The end result will be the same, I should say.
Posted: Sat Jun 29, 2013 7:14 pm
rimai wrote:They are both the same.
I would argue that... partially...
the first one is one step away from being able to utilize the portal to change modes. but both are currently locked to the programmed mode and speed.
the first one though will use much more memory as has been discovered by others. So unless you have an RA+ I would not use the first as written.
