Edwin's Custom Reef Angel...
Posted: Thu Jul 04, 2013 5:55 am
Hello, I was hoping to get some help from Lnevo on customizing my reef Angel, I currently have:
Tank:
120 Gallon (w 2 MP 40s)
57 galllon (w 1 MP 40)
Equipment:
RA+ with WiFi, RF expansion and 2 dosers.
My ports are
1 - return pump
2- refuge lights
3- T5 ballast
4 - Doser Alk
5 - Frag tank light (fantom LED Par 38)
6 - Doser Calc
7- Heater
8 - Skimmer
Problem #1 - Dosers
So I tested them out by running them for 10 mins into a 300 ml cup.
One pump filled the cup in 10 mins for a flow rate of .5ml/s
The other pump had a flow rate of .295ml/sec (178 ml in 10 mins (600 seconds)
I read that Lnevo can get the pumps to calibrate based on volume... So Im hoping he can help me calibrate the pumps...
Problem #2 - MP40s
As my tank setup I currently have 3 mp 40s, 2 in the 120 (pumps 1,2) an 1 in the 57 (pump 3)... I can only control the 2 in the 120 (i made all three slaves on the Ecotech). But the RF is not picking up the 3.
Ideally i would like to do the following:
- Run 1,2 in anti-synch mode
- Run 3 in Synch mode
- Have a custom menu where i can switch modes on the fly from my controller head or phone...
***FYI I cannot do internal memeory b\c my kids play with my phone too much and dont need them pressing buttons... So i just upload my code...
SO here is my code. Thanks in advance for all help
Tank:
Equipment:
My ports are
1 - return pump
2- refuge lights
3- T5 ballast
4 - Doser Alk
6 - Doser Calc
7- Heater
8 - Skimmer
Problem #1 - Dosers
Problem #2 - MP40s
#include <RF.h>fa
ReefAngel.WaterChangePorts = Port1Bit | Port8Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
ReefAngel.FeedingModePorts = Port1Bit | Port6Bit | Port8Bit; // Turn off Ports 1, 6, 7 and 8 when Water Change Mode is activated
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit| Port5Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit |Port3Bit | Port4Bit | Port5Bit | Port7Bit; // Turn off Ports 3,
// Setup ATO Port for AI communication
ReefAngel.AI.SetPort( lowATOPin );
ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.StandardLights( Port3,11,0,16,0 );
ReefAngel.StandardLights( Port4,11,0,20,0 );
ReefAngel.StandardLights( Port5,9,0,19,0 );
ReefAngel.StandardHeater( Port7,780,800 );
ReefAngel.Relay.DelayedOn( Port8,2 ); //Skimmer
ReefAngel.AI.SetChannel( White, PWMParabola(11,0,17,0,0,75,0) );
ReefAngel.AI.SetChannel( Blue, PWMParabola(9,0,20,0,15,100,0) );
ReefAngel.AI.SetChannel( RoyalBlue, PWMParabola(9,0,20,0,15,100,(MoonPhase()/5)<3 ? 3:MoonPhase()/5) );
ReefAngel.RF.SetMode( ReefCrest,85,10 );
ReefAngel.RF.SetChannel( Radion_White, PWMParabola(9,0,20,0,0,60,0) );
ReefAngel.RF.SetChannel( Radion_RoyalBlue, MoonPhase() );
ReefAngel.RF.SetChannel( Radion_Red, PWMParabola(9,0,20,0,15,65,15) );
ReefAngel.RF.SetChannel( Radion_Green, PWMParabola(9,0,20,0,15,50,15) );
ReefAngel.RF.SetChannel( Radion_Blue, MoonPhase() );
ReefAngel.RF.SetChannel( Radion_Intensity, PWMParabola(9,0,20,0,15,94,15) );
if ( second()==0 ) ReefAngel.RF.RadionWrite();
if (hour()>=6 && hour()<11)
ReefAngel.RF.SetMode(ReefCrest,85,10);
else if (hour()>=11 && hour()<13)
else if (hour()>=13 && hour()<16)
ReefAngel.RF.SetMode(Smart_NTM,85,15);
else if (hour()>=16 && hour()<19)
ReefAngel.RF.SetMode(ReefCrest,65,10);
ReefAngel.RF.SetMode(Lagoon,40,10);
// Hardcode PH calibrations
ReefAngel.PHMin=544; // PH7.0
ReefAngel.PHMax=830; // PH10.0
ReefAngel.Portal( "ecam" );
int x,y;
// Aqua Illumination
x = 10;
y = 20;
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x,y,"WH:" );
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+38,y,"BL:" );
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+76,y,"RB:" );
for ( int a=0;a<3;a++ )
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+18,y,ReefAngel.AI.GetChannel(a) );
x += 38;
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
// Main Relay Box
// Date and Time
