the VGA cable disconnected its the only method i found to get the relay box to normal activity. Like a reboot.
int avgph[10];
unsigned long totalavgph=0;
byte avgindex=0;
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port3Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port6Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port7Bit ;
ReefAngel.Relay.On( Port5 );
for (int a=0;a<10;a++) avgph[a]=analogRead(PHPin);
totalavgph=0;
avgph[avgindex]=analogRead(PHPin);
avgindex++;
if (avgindex==10) avgindex=0;
totalavgph+=avgph[a];
totalavgph/=10;
totalavgph=map(totalavgph, ReefAngel.PHMin, ReefAngel.PHMax, 700, 1000); // apply the calibration to the sensor reading
totalavgph=constrain(totalavgph,100,1400);
if (totalavgph <= 639) ReefAngel.Relay.Off(Port3);
if (totalavgph >= 652) ReefAngel.Relay.On(Port3);
// ReefAngel.CO2Control( Port3,644,655 );
ReefAngel.StandardFan( Port4,780,788 );
ReefAngel.StandardLights( Port7,0,30,12,30 );
ReefAngel.WavemakerRandom( Port6,1200,240 );
ReefAngel.StandardLights( Port8,12,0,2,0 );
ReefAngel.PWM.SetDaylight(PWMSlope(17,0,0,3,0,12,3,0));
ReefAngel.PWM.SetDaylight(PWMSlope(18,30,22,33,12,45,3,ReefAngel.PWM.GetDaylightValue()));
ReefAngel.PWM.SetActinic( PWMSlope(15,0,1,0,9,60,60,9) );
ReefAngel.Portal( "Bo0sted_Rafi" );
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawText(0,255,3,17," Rafi's 75 Reef");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
ReefAngel.LCD.DrawText(0,255,10,30,"Display");
ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 10, 40, text);
ReefAngel.LCD.DrawText(0,255,90,30,"CA pH");
ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 95, 40, text);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
ReefAngel.LCD.DrawText(0,255,8,100, "White");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
ReefAngel.LCD.DrawText(0,255,88,100, "Blue");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,90,119, ReefAngel.PWM.GetActinicValue());
