wiffi module help
Posted: Wed Jul 10, 2013 9:17 pm
by iiluisii
I'm trying to set up my wiffi module to my new router and its not wanting to connect for some reason..the blue led stays blinking…here is a picture of what the set up page showed,, i notice that on associated and authenticated it say false and on the instructions it shows true
Re: wiffi module help
Posted: Thu Jul 11, 2013 8:51 am
Make sure your router is set to WPA2-PSK with AES encryption.
It's the most secure and the one we have had fewer problems with, if any.
Posted: Thu Jul 11, 2013 10:15 am
by iiluisii
rimai wrote:Make sure your router is set to WPA2-PSK with AES encryption.
How do I set it up WPA2-PSK with AES
Posted: Thu Jul 11, 2013 10:54 am
by iiluisii
Ok all I can find is WPA2 personal and enterprise I don't see the one you are listing. Not to sound rude but I'm kind of getting tired of the reef angel since I had 2 ph probes have gone bad and this wifi adapter have been non but problems plus there is not quick support phone line of any kind. plus any time you need support you have to wait until someone reply on this forum.. if I can not fix this and get it working again I will be gettin rid of it and going with an apex
Posted: Thu Jul 11, 2013 10:59 am
It's WPA2 Personal.
Posted: Thu Jul 11, 2013 11:05 am
by iiluisii
I tried that and not working some how the wifi adapter is not associating
Posted: Thu Jul 11, 2013 11:19 am
SSID and passphrase are case sensitive.
Make sure you are typing them in the same case as you have setup in your router.
Posted: Thu Jul 11, 2013 11:20 am
by iiluisii
rimai wrote:SSID and passphrase are case sensitive.
This has also been done. They are typed just like the router
Posted: Thu Jul 11, 2013 11:39 am
by iiluisii
got it working don't know how but i unplug everything..router,reef angel and started it again and its working…. :oops:
Posted: Thu Jul 11, 2013 12:06 pm
by Sacohen
Sometime everything just needs a good kick in the butt to remind it who's boss.
Posted: Sat Jul 27, 2013 4:50 am
by iiluisii
Well back again to a non working wifi module. It was working great for about 20 days and not it's not working again time to start saving for an apex Im done with this for now I'm gonna try the Ethernet mod and see how that works
Posted: Sat Jul 27, 2013 5:25 am
Do you have the 4.0 firmware? You might want to try the antenna mod. For $7 that seems to have helped a few people with intermittent connectivity issues.
