Help - RA has started to randomly turn off skimmer!
Posted: Fri Jul 12, 2013 3:01 am
As above, my skimmer is on port 3, and the only code I have affecting the skimmer is a float switch in the skimmer lid to turn of the skimmer if fills - have checked the switch and is all working fine?
I am at a loss as to what is happening. Luckily, it has happened 2 times whilst I have been nearby and managed to catch it.
If I use the portal or iphone app, I am able to turn the skimmer back on.
Any advise please, as its a bit concerning if Im out and my skimmer turns off.
I look forward to your advise!!
unsigned long lastLowSal=now();//salinity >35.1 timer
boolean SALduration=true;//salinity >35.1 for 2 minutes flag
boolean ATOEnabled=false;//enable ATO function for 5 seconds
boolean ATOPumping=true;//disable ATO function for 5 minutes
unsigned long ATOStart=now();//ATO 5 sec run timer
double Salinitytest;
InternalMemory.OverheatTemp_write( 260 );
InternalMemory.SalTempComp_write( 255); // Change this to compensation temperature
ReefAngel.Relay.On( Port4 );
ReefAngel.Timer[1].SetInterval(1800); // 30 mins before reactivation of ATO
ReefAngel.Relay.DelayedOn( Port3,5 );//skimmer delay on switching on
ReefAngel.StandardHeater( Port6,252,255 );
ReefAngel.StandardFan( Port7,255,258 );
ReefAngel.WaterLevelATO(Port2,180,35,40);// Salinty top up to keep water level correct
// Apply Salinity temp Compensation & salinity calibration
double SalCompensation;
if (ReefAngel.TempSensor.unit)
SalCompensation=ReefAngel.Params.Salinity/(1+((ReefAngel.Params.Temp[T3_PROBE]-InternalMemory.SalTempComp_read())*0.0022));
SalCompensation=ReefAngel.Params.Salinity/(1+((ReefAngel.Params.Temp[T3_PROBE]-InternalMemory.SalTempComp_read())*0.001165));
SalCompensation=round(SalCompensation);
// For displaying salinity without temp compensation
Salinitytest=SalCompensation;
///// If salinity >35.1 for 120 sec set SALduration flag
if (SalCompensation<351) lastLowSal=now();
if (now()-lastLowSal>120) SALduration=false;
if (SALduration && ATOPumping)//if salinity>35.1 for 2 minutes enable ATO
{ATOStart=now();
ATOEnabled=true;
ATOPumping=false;
if (now()-ATOStart<5)//ATO pump on time 5 seconds
if (ATOEnabled) ReefAngel.Relay.On(Port1);
ReefAngel.Timer[1].Start();//start 5 minute disable of ATO
ReefAngel.Relay.Off(Port1);
ATOEnabled=false;
if (ReefAngel.Timer[1].IsTriggered())//after 30 minute disable, enable ATO
ATOPumping=true;
ATOStart=now();
SALduration=true;
///// if skimmer cup full, turn off skimmer
bitClear(ReefAngel.Relay.RelayMaskOff,2);
else {
bitSet(ReefAngel.Relay.RelayMaskOff,2);
ReefAngel.Portal( "dazza1304" );
int x,y;
// Parameters
// Salinity
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,15,46, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,39,46, ReefAngel.Params.Salinity );
//map of adc temp comp salinity
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,15,63, "SAT:" );
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,39,63, (int)Salinitytest );
// ORP
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,75,46, "ORP:" );
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,99,46, ReefAngel.Params.ORP );
// Water Level
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,75,63, "WL:" );
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,99,63, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 79, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 98, TempRelay );
// Date and Time
