How do I get the portal to see my new relay expansion?
Posted: Sat Jul 13, 2013 3:13 pm
by Smotz
Hi
Just installed the expansion module and relay expansion. How do I get the portal to recognize my new (8) ports?
my code:
////  Port 1			Heater
////  Port 2			ATO pump
////  Port 3			Reactor Pump
////  Port 4			Protien Skimmer
////  Port 5			Return Pump
////  Port 6			Wavemaker
////  Port 7                    UV Sterilizer
////  BOX 1 PORT 8              Fuge Light
////  Always on - Lights & Salinity Module
#define Heater Port1
#define Topoff Port2
#define Reactor Port3
#define Skimmer Port4
#define Return Port5
#define Wave Port6
#define UVlight Port7
#define Fugelight Box1_Port8
#define FugelightBit   2<<7
#define UVlightBit   1<<6
#define WaveBit   1<<5
#define ReturnBit   1<<4
#define SkimmerBit   1<<3
#define ReactorBit   1<<2
#define TopoffBit   1<<1
#define HeaterBit   1<<0
static byte wpMode;
static byte wpWavStr;
static byte wpWavOff;
  ReefAngel.FeedingModePorts = TopoffBit | ReactorBit | SkimmerBit | ReturnBit | UVlightBit;
  ReefAngel.WaterChangePorts = HeaterBit | TopoffBit | ReactorBit | SkimmerBit | ReturnBit | WaveBit | UVlightBit;
  ReefAngel.LightsOnPorts = FugelightBit;
  ReefAngel.OverheatShutoffPorts = HeaterBit | TopoffBit | ReactorBit | SkimmerBit | ReturnBit | WaveBit | UVlightBit;
  // Use T1 (SUMP) probe as temperature and overheat functions
  ReefAngel.Relay.On( Return );
  ReefAngel.Relay.On( Reactor );
  ReefAngel.Relay.On( Wave );
  ReefAngel.StandardHeater( Heater );
  ReefAngel.StandardATO( Topoff );
  ReefAngel.MoonLights( Fugelight );
  ReefAngel.LCD.DrawText(0,255,20,80,"Joe's Reef Tank");
  ReefAngel.Relay.DelayedOn(Skimmer,2);
  ReefAngel.Relay.DelayedOn(UVlight,1);
  ReefAngel.DCPump.FeedingSpeed=30;
  //if (ReefAngel.DCPump.Mode==Custom) ReefAngel.DCPump.UseMemory = false;
  //else ReefAngel.DCPump.UseMemory = true;
  // Custom Wave Routine
  if (ReefAngel.DCPump.Mode==Custom) {
    // set the wpMode
    if ( (hour() >= 5) && (hour() < 8) )   wpMode=1;       // from 5am - 8am
    if ( (hour() >= 8) && (hour() < 11) ) wpMode=2;      // from 8am - 11am
    if ( (hour() >= 11) && (hour() < 14) ) wpMode=3;     // from 11a - 2pm
    if ( (hour() >= 14) && (hour() < 17) ) wpMode=2;     // from 2pm - 5pm
    if ( (hour() >= 17) && (hour() < 20) ) wpMode=1;     // from 5pm - 8pm
    if ( (hour() >= 20) && (hour() < 23) ) wpMode=2;     // from 8pm - 11p
    if ( (hour() >= 23) && (hour() < 2) ) wpMode=3;      // from 11pm - 2am
    if ( (hour() >= 2) && (hour() < 5) ) wpMode=2;       // from 2am - 5am
    if (wpMode=1) wpWavStr=45;
    if (wpMode=2) wpWavStr=50;
    if (wpMode=3) wpWavStr=55;
    //Set the Wave OffSet
    wpWavOff=12;
    //if (ReefAngel.DisplayedMenu==FEEDING_MODE) ReefAngel.PWM.SetDaylight(30);
    //else
    ReefAngel.PWM.SetDaylight( ReefCrestMode(wpWavStr,wpWavOff,true) );
    ReefAngel.PWM.SetActinic(wpWavStr);
  // end Custom Wave Routine
    //  Only turn on UV Sterilizer between 11pm and 5am
  if ( (hour() >= 5) && (hour() < 23) )  // from 5a - 11p
    ReefAngel.Relay.Off(UVlight);
  else ReefAngel.Relay.On(UVlight);
  ReefAngel.Portal( "Smotz" );
  // Salinity
  ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
  ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
 // Relay Expansion
  ReefAngel.LCD.DrawOutletBox( 12, 102, TempRelay );
  //draw the mode on the screen
  char buf[16];
  if (ReefAngel.DisplayedMenu==FEEDING_MODE) sprintf(buf,"Pumps at %d%%",ReefAngel.DCPump.FeedingSpeed);
  else sprintf(buf,"RC %d%% +/- %d%%",wpWavStr,wpWavOff);
  ReefAngel.LCD.DrawText(0,255,15,52,buf);
Re: How do I get the portal to see my new relay expansion?
Posted: Sat Jul 13, 2013 3:31 pm
by rossbryant1956
put a line this in your code calling one of the outlets on th esecond box
ReefAngel.Relay.On( Fuge Light );
Not sure it will take that space between fuge and light
Posted: Sat Jul 13, 2013 4:09 pm
Portal will do it automatically as soon as you upload a new code that uses one of the ports in the expansion box.
Posted: Sat Jul 13, 2013 5:18 pm
by Smotz
rimai wrote:Portal will do it automatically as soon as you upload a new code that uses one of the ports in the expansion box.
This is in my code but the Portal is not showing my new expansion box:
Posted: Sat Jul 13, 2013 6:04 pm
The last time your controller sent data was 2 days ago. Something else is going on.
Posted: Sat Jul 13, 2013 6:42 pm
by Smotz
rimai wrote:The last time your controller sent data was 2 days ago. Something else is going on.
Ok fixed that. You'll notice that the portal has communicated recently. Still no expansion...??
wtf?? it said it was updated but now i look at it and it says 2 days ago
and now its back to recent
My reefangelid:
Smotz
Connection Status:
Ready
Last Update:
7/13/2013 9:45:07 PM
Displaying data from:
Reef Angel Controller (live)
Posted: Sat Jul 13, 2013 6:47 pm
by Smotz
and theres my relay...
thanks everyone. I needed to reset my wifi adapter back to factory and reconfig.
Now I need to see why bluetooth isnt working.
