#include <WiFiAlert.h>
// Globals for Params on Custom Main
byte x,y;
// Define Custom Variables for Portal
#define Var_Power 1
// Custom Menu
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Turn Lights On";
prog_char menu1_label[] PROGMEM = "Turn Lights Off";
prog_char menu2_label[] PROGMEM = "Start Feeding";
prog_char menu3_label[] PROGMEM = "Start Water Change";
prog_char menu4_label[] PROGMEM = "Clear Overheat";
prog_char menu5_label[] PROGMEM = "Calibrate pH";
prog_char menu6_label[] PROGMEM = "Calibrate Salinity";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label };
void MenuEntry1()
ReefAngel.DisplayMenuEntry("Item 1");ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif // RelayExp
ReefAngel.Relay.Write();
void MenuEntry2()
ReefAngel.DisplayMenuEntry("Item 2");ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif // RelayExp
void MenuEntry3()
ReefAngel.DisplayMenuEntry("Item 3");ReefAngel.FeedingModeStart();
void MenuEntry4()
ReefAngel.DisplayMenuEntry("Item 4");ReefAngel.WaterChangeModeStart();
void MenuEntry5()
ReefAngel.DisplayMenuEntry("Item 5");ReefAngel.OverheatClear();
void MenuEntry6()
ReefAngel.DisplayMenuEntry("Item 6");ReefAngel.SetupCalibratePH();
void MenuEntry7()
ReefAngel.DisplayMenuEntry("Item 7");ReefAngel.SetupCalibrateSalinity();
// End Custom Menu Globals
// Define Relay Ports by Name
#define DT_LightsOne 1
#define DT_LightsTwo 2
#define Unused3 3
#define Unused4 4
#define DT_LWM 5
#define GT_LWM 6
#define Unused7 7
#define Unused8 8
#define Unused11 Box1_Port1
#define Unused12 Box1_Port2
#define GT_LightsOne Box1_Port3
#define GT_LightsTwo Box1_Port4
#define DT_RWM Box1_Port5
#define GT_RWM Box1_Port6
#define DT_Heat Box1_Port7
#define DT_Pump Box1_Port8
#define RV_Heat Box2_Port1
#define RV_Pump Box2_Port2
#define GT_Heat Box2_Port3
#define Unused24 Box2_Port4
#define Unused25 Box2_Port5
#define Unused26 Box2_Port6
#define Skimmer Box2_Port7
#define GT_Pump Box2_Port8
void setup() {
ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize the menu
ReefAngel.FeedingModePorts = DT_LWM | GT_LWM | GT_Pump | DT_Pump | DT_RWM | GT_RWM | Skimmer; // Turn off when feeding mode is activated is activated
ReefAngel.WaterChangePorts = DT_Heat| DT_LWM | DT_RWM | GT_LWM | GT_RWM | GT_Pump | DT_Pump; // Turn off when water change mode is activated
ReefAngel.TempProbe = T2_PROBE; // Set the 2nd plug to be DT Main temp
ReefAngel.OverheatProbe = T2_PROBE; // to monitor the overheat and temperatures
ReefAngel.OverheatShutoffPorts = DT_LightsOne | DT_LightsTwo | DT_Heat | GT_LightsOne | GT_LightsTwo | GT_Heat | Skimmer; // Items turned off when Overheat temperature exceeded
InternalMemory.OverheatTemp_write( 829 ); // Set the DT Overheat temperature setting
ReefAngel.LightsOnPorts = DT_LightsOne | DT_LightsTwo | GT_LightsOne | GT_LightsTwo; // Toggle Lights
// Ports that default on
ReefAngel.Relay.On(DT_Pump); // Turn on DT Pump
ReefAngel.Relay.On(GT_Pump); // Turn on GT Pump
ReefAngel.Relay.On(Skimmer); // Turn on Skimmer
CheckPower(); // Monitor for power outages
ReefAngel.StandardLights( DT_LightsOne,14,00,22,00 ); // DT Lights on at 2:00pm and off at 10:00pm
ReefAngel.StandardLights( DT_LightsTwo,22,00,01,00 ); // DT-Moon Lights on at 10:00am and off at 1:00am
ReefAngel.StandardLights( GT_LightsOne,14,00,21,45 ); //GT Lights Main 2:00pm - 9:45pm
ReefAngel.StandardLights( GT_LightsTwo,15,00,22,30 ); //GT Lights Actinic 3:00pm - 10:30pm
ReefAngel.WavemakerRandom( DT_LWM,60,100 );
ReefAngel.Relay.Set( DT_RWM, !ReefAngel.Relay.Status( DT_LWM ) ); //Randomize DT powerheads
ReefAngel.WavemakerRandom1( GT_LWM,60,100 );
ReefAngel.Relay.Set( GT_RWM, !ReefAngel.Relay.Status( GT_LWM ) ); //Randomize GT powerheads
StandardHeater1( DT_Heat,779,791 ); //DT-Heat
StandardHeater2( GT_Heat,779,791 ); //GT-Heat
// if the hour is 2p or 8p, minute is 55 and seconds is 0, start the feeding mode
if ( ((hour() == 14) || (hour() == 20)) &&
(minute() == 55) &&
(second() == 0) )
if (hour()>=1 && hour()<6) // Turn on Reservoir Pump
ReefAngel.Relay.On(RV_Pump);
ReefAngel.Relay.Off(RV_Pump);
// turn on RV_Heat when temp falls below 76.0 and turn off when temp gets above 80.0
if (ReefAngel.Params.Temp[T3_PROBE] <= 780 && ReefAngel.Params.Temp[T3_PROBE] > 0) ReefAngel.Relay.On(RV_Heat);
if (ReefAngel.Params.Temp[T3_PROBE] >= 791) ReefAngel.Relay.Off(RV_Heat);
//turn off DT pump when switch is tripped and sound buzzer
//ReefAngel.Relay.Set(DT_Pump,ReefAngel.IO.GetChannel(0));
//ReefAngel.PWM.SetDaylight(100-(ReefAngel.IO.GetChannel(0)*100));
//turn off GT pump when switch is tripped and sound buzzer
// ReefAngel.Relay.Set(GT_Pump,ReefAngel.IO.GetChannel(1));
// ReefAngel.PWM.SetDaylight(100-(ReefAngel.IO.GetChannel(1)*100));
//tell the portal we have a overflow problem
// ReefAngel.CustomVar[0]=ReefAngel.IO.GetChannel(0);
// ReefAngel.CustomVar[1]=ReefAngel.IO.GetChannel(1);
// ReefAngel.CustomVar[7]=1;
//set up dosing pump one to run twice a week for 4 minutes
//ReefAngel.Relay.Set(Box1_Port2,((weekday()==1||weekday()==4) && hour()==14 && minute()<6));
//ReefAngel.Relay.Set (Box1_Port3,(hour()%2==0)); //stir chemicals in water top off unit
ReefAngel.Portal("rossbryant1956");
void CheckPower() {
static boolean powerOutage=false;
static WiFiAlert powerAlert;
// Power Outage - turn off everything
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY))
// && (!ReefAngel.Relay.IsRelayPresent(EXP2_RELAY))) // Expansion Relay NOT present
powerOutage=true;
ReefAngel.Relay.Off(DT_LightsOne);
ReefAngel.Relay.Off(DT_LightsTwo);
ReefAngel.Relay.Off(Port3);
ReefAngel.Relay.Off(Port4);
ReefAngel.Relay.Off(Port7);
ReefAngel.Relay.Off(Port8);
powerAlert.Send("Power+Outage!");
//ReefAngel.CustomVar[Var_Power]=1;
// Power Restored - Turn things back on
if (powerOutage && ReefAngel.Relay.IsRelayPresent(EXP1_RELAY)) // Expansion Relay NOT present
powerOutage=false;
LastStart=now();
powerAlert.Send("Power+restored.",true);
// ReefAngel.CustomVar[Var_Power]=1;
void StandardHeater1(byte HeaterRelay, int LowTemp, int HighTemp)
if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
void StandardHeater2(byte HeaterRelay, int LowTemp, int HighTemp) //Heater for Grow Tank
if (ReefAngel.Params.Temp[T1_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T1_PROBE] <= LowTemp && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T1_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor temperature >= HighTemp - turn off heater
int x,y;
char text[7];
ReefAngel.LCD.DrawDate( 6, 122 ); //6 pixels left, 122 lines down
// I/O Expansion
byte bkcolor;
x = 14;
y = 11;
for ( int a=0;a<6;a++ )
if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE; else bkcolor=COLOR_GRAY;
ReefAngel.LCD.DrawText(0,255,18,26,"GT"); //18 left, 10 down
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 37, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,57,26,"DT"); //57 left, 10 down
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 50, 37, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,94,26,"Res"); //94 left, 10 down
ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 90, 37, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,16,52,"DT pH"); //18 left, 39 down
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 15, 65, text, Num8x8);
ReefAngel.LCD.DrawText( 0,255,57,52, "GT pH"); //57 left, 39 down
ConvertNumToString(text, ReefAngel.Params.PHExp, 100);
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 55, 65, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,100,52,"Sal"); //100 left, 39 down
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 98, 65, text, Num8x8);
ReefAngel.LCD.DrawOutletBox( 12, 80, TempRelay );
// Relay Expansion
// Relay Expansion
TempRelay = ReefAngel.Relay.RelayDataE[1];
TempRelay &= ReefAngel.Relay.RelayMaskOffE[1];
TempRelay |= ReefAngel.Relay.RelayMaskOnE[1];
// ReefAngel.LCD.DrawGraph( 5, 5 );
void CheckPower() {
powerOutage=true;
powerOutage=false;
LastStart=now();
}So, Thx in advance, hope you see something I don't.
