Page 1 of 2
Customizing Delayed start
Posted: Mon Jul 15, 2013 7:55 pm
by ganjero
Can I change what activates the delay start? I use it on my skimmer for feed mode but I don't want to use for water changes or controller reset (it's turns of my skimmer every time i tried a new code)
Re: Customizing Delayed start
Posted: Tue Jul 16, 2013 4:31 pm
by ganjero
any ideas here?
Posted: Tue Jul 16, 2013 4:34 pm
What do you want it based on? It can be based on anything we can test or compare
Posted: Tue Jul 16, 2013 4:57 pm
by ganjero
The main thing I want to get rid off is that it gets trigger anytime a new code is uploaded, if this cannot be change can i program the skimmer for a delay start with a different code?
Posted: Tue Jul 16, 2013 5:13 pm
Yeah that is doable. I think I'd like it too. Give me some time and I'll have something.
Posted: Tue Jul 16, 2013 6:24 pm
by ganjero
Great, thanks
Posted: Thu Jul 18, 2013 5:46 pm
by ganjero
lnevo wrote:Yeah that is doable. I think I'd like it too. Give me some time and I'll have something.
Did you have time to come up with something?
Posted: Thu Jul 18, 2013 6:19 pm
Not yet..I'll try tomorrow on the train. I left my kindle at work
Posted: Fri Jul 19, 2013 5:44 am
Ok this was much easier than I thought. There is a variable called RAStart that is defined when the controller boots up and initially LastStart s assigned the same variable. After mode changes LastStart is updated...but not RAStart. So, if RAStart==LastStart we just booted. The problem I had as how to differentiate between a reboot and an extended outage. Well for me if my HighATO is active that means my sump water level is normal so I added a check for that. You may need to change that based on your setup or take that part out completely.
if (RAStart==LastStart && ReefAngel.HighATO.IsActive()) {
ReefAngel.Relay.On(Port2);
} else {
ReefAngel.Relay.DelayedOn(Port2);
So what this does is at initial boot, the port is an "always on" port. Once a feeding or waterchange mode change is exited it becomes a DelayedOn port. I have not tested it yet, but it should do the trick.
Posted: Fri Jul 19, 2013 6:07 am
by ganjero
Thanks a lot.
I guess I will try this:
if (RAStart==LastStart ) {
ReefAngel.Relay.On(Port7);
} else {
ReefAngel.Relay.DelayedOn(Port7);
I am not using the water sensors yet so as you said I eliminated the HighATO part, and my skimmer is on port 7 so I changed that too. Does this seem correct? I will try it tonight and give you feedback.
Thanks again.
Posted: Fri Jul 19, 2013 7:52 am
Yes, that should work fine. Like I said, I haven't had a chance to test yet, so you'll save me some time if you get to try it tonight
Just keep in mind if you have any delayed power outage or downtime on your controller when it comes back up your skimmer *may* overflow if the return pump hasn't caught up.
Posted: Sat Jul 20, 2013 9:34 am
It did not work for me. For some reason RAStart is getting assigned 0, but somehow LastStart which gets assigned = to RAStart has a value. No big deal... this is what i did to fix in the meantime.
static unsigned long startTime=now();
if (startTime==LastStart && ReefAngel.HighATO.IsActive()) {
ReefAngel.Relay.On(relay);
} else {
ReefAngel.Relay.DelayedOn(relay);
It worked really nice especially with the float switch in there. if I reload code, skimmer does not stop. If I unplug RA and the water level is too high, as soon as float switch drops skimmer kicks back in. Awesome.
Posted: Sat Jul 20, 2013 2:18 pm
by ganjero
Worked for me, thanks a lot. I guess I will have to install the float sensors to differentiate booting from power outage.
Thanks again
Posted: Sun Jul 21, 2013 10:24 am
by ganjero
I noticed that after using this the time and date get messed up, did this happen to you?
Posted: Sun Jul 21, 2013 10:59 am
No
Posted: Fri Jul 26, 2013 6:38 pm
by ganjero
If I have this line will my port7 be delayed 60 sec or an hour?
ReefAngel.Relay.DelayedOn( Port7,60 );
Posted: Fri Jul 26, 2013 7:09 pm
An hour. If you leave out the 60 you can set the time in the portal.
Posted: Fri Jul 26, 2013 9:45 pm
by ganjero
why some things have to be set in seconds? and how do I know that ie,
static time_t StartFeeding=0;
StartFeeding=now(); // if we entered feeding mode, register what time it was.
if (now()-StartFeeding > 1800 && now()-StartFeeding < 5400) // if feeding started between 1800 and 5400 seconds
ReefAngel.PWM.SetActinic(100);
ReefAngel.PWM.SetActinic(45);
Posted: Fri Jul 26, 2013 10:05 pm
You don't need to... It's just easier to
The code above can be coded in minutes, hours or whatevern you want.
It was a preference choice of the programmer that made the code to go with seconds.
If it were me, I would have coded it in seconds too, just because it is easier to understand.
Posted: Sat Jul 27, 2013 6:23 am
by ganjero
So I could do tthis to delay port 7 for half hour? I guess what im trying to know is how to figure out how to tell the controller whether Im using minutes or seconds
ReefAngel.Relay.DelayedOn( Port7,1800 );
Posted: Sat Jul 27, 2013 7:23 am
What decides is how the function is written. DelayedOn uses minutes. So just use 30.
Aside from convenience and preference as Roberto pointed out, it is also determined by memory usage (byte vs int) and what makes sense. When writing functions now() returns seconds so thats why it's easy. But looking at delayed on it was determined that no one needed to delay in seconds only so minutes were used. This also makes it easy to store the DelayedOn default time in memory because a byte can be used instead of an int (100% savings!!)
To represent 15 minutes in seconds would be 900 and require an int for storage instead of a byte. It may not seem like much but they all add up.
Posted: Sat Jul 27, 2013 9:31 am
by binder
Yep. When I wrote DelayedOn, the delay of seconds didn't seem appropriate because most people wanted a 1 or 2 minute (maybe even 5 minute) delay so their tanks would fill back up before the power heads started working (like in my case).
Plus, like Lee said, it's a storage issue as well as a convenience.
Now, if we were to look at the WavemakerRandom function, it makes more sense to use seconds because you may want it to run every 30 seconds before alternating or 90 seconds or something along those lines. You can't code in 1.5 for a a minute and a half, so you would be better suited for 90 seconds.
Posted: Sat Jul 27, 2013 1:13 pm
by ganjero
Make sense, so the delayon function is in the libraries based in minutes. Thanks
Why is my skimmer coming back on after 15min instead of an hour in my code?
ReefAngel.FeedingModePorts = Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit;
// Use T2 probe as temperature and overheat functions
InternalMemory.OverheatTemp_write( 851 );
//Feeedin mode length
ReefAngel.Timer[FEEDING_TIMER].SetInterval(300);
ReefAngel.Relay.On( Box1_Port1);
ReefAngel.StandardLights( Port1,14,0,19,0 );
ReefAngel.StandardLights( Port2,15,0,20,0 );
ReefAngel.StandardLights( Port3,19,55,22,0 );
ReefAngel.StandardLights( Port4,14,0,20,15 );
ReefAngel.StandardHeater( Port5,780,785 );
ReefAngel.StandardFan( Port6,780,800 );
ReefAngel.StandardLights( Box1_Port5,22,0,16,0 );
////disable ReefAngel.PWM.SetDaylight( ElseMode(70,30,true )); // ElseMode on sync mode, 70 +/- 30%
ReefAngel.PWM.SetDaylight( ReefCrestMode(70,30,true) ); // ReefCrest at 70% +/- 30% on sync mode
//// Jebao sump pump runs at 45% unless feeding, then a 30min runs at 100% 1hr.
///// Delay Start Turn off on Booting - Start
if (startTime==LastStart) {
} else {
///// Delay Start Turn off on Booting - End
ReefAngel.Portal( "ganjero" );
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 62, ReefAngel.Params,
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 107, TempRelay );
//// Jebao Else Mode - Start
if (WaveSync)
return NewSpeed;
return AntiSpeed;
//// Jebao Else Mode - End
Posted: Sat Jul 27, 2013 2:19 pm
Looks good. As I said RAStart didn't work for me for some reason... may revisit it later...
Posted: Sat Jul 27, 2013 6:01 pm
You have 2 Port7 referenced in two places.
And
} else {
The second one will always override the 1st one.
Posted: Sat Jul 27, 2013 7:13 pm
The last one is using InternalMemory to set the delay. Check on the portal your default delay may be 15 minutes...
Posted: Mon Jul 29, 2013 8:38 am
by ganjero
That's it! learning more everyday
so should I delete the first reference and just adjust the delay in portal so I can keep the code that prevents triggering the delay on reboots?
Can I also fix this by deleting the first reference and just adding the time on the second reference? like this:
} else {
ReefAngel.Relay.DelayedOn(Port7,60);
Thank you
Posted: Mon Jul 29, 2013 8:40 am
Yes, you got it
Posted: Mon Jul 29, 2013 9:37 am
If you just take out the ,60 you will have best of both worlds. Set the delay time in the portal and have it not delay on reboots.
Posted: Mon Jul 29, 2013 10:54 am
by ganjero
You mean delete
ReefAngel.Relay.DelayedOn( Port7,60);
and leave this one like this:
} else {
