Something happened to my controller, I was trying to to upload a code and something went wrong.
The screen doesnt light up, the green LED is on and the red one keeps blinking, some outlets are on and some arent.
What should I do?
Emergency help
Re: Emergency help
Try unplugging and leave it off for a few seconds and turn it on again.
Does it bring it back?
ganjero
Re: Emergency help
No, it does the same. I was uploading the code; I have a mac and I think I bumped the trackpad and I think that cliked on upload again.
Btw now none of the outlets are on.
ganjero
Re: Emergency help
Im getting this error if I try to upload a code
Re: Emergency help
Is the controller just blinking now and nothing in the screen?
Try disconnecting everything to bare minimum. Does it make a difference?
Do you have RA or RA+?
If you have RA+, try connecting the head unit disconnected from the relay box using the usb power cable.
ganjero
Re: Emergency help
Got it working, I noticed the size of the code went from 43 to 32....I guess when I bumped the trackpad i deleted stuff from the code right before I mistakenly hit upload. I did try uploading the preloaded code but did not work....probably one of the steps described above combined with a fresh code helped.
Thank you
btw I have the RA+
Thank you
btw I have the RA+
