Help with Port Forwarding on 2Wire
Posted: Tue Jul 23, 2013 8:57 pm
by ReefingHavoc
I'm setting up my RA+ for the first time and trying to get the Wifi connected. I've spent about 3 hrs reading through websites on port forwarding for 2Wire (Uverse) and RA forums -- I'm stumped. I thought I had the setup done correctly through the router so I tried opening ports on Windows Firewall as well as AVG (even turned both off) but when I go to a site like YouGetSignal it says port 2000 is closed. I'm attaching a screenshot from Uverse/2Wire setup. To clarify, IP 192.xx.x.xxx is the router (2wire).
Hoping someone has had success in their setup.
Mike
Re: Help with Port Forwarding on 2Wire
Posted: Thu Jul 25, 2013 10:08 pm
by ReefingHavoc
Problem solved. I realized that I was using an outdated WiFi utility and instructions. Once I used the latest utility was easily able to get the ball rolling.
Posted: Sat Jul 27, 2013 9:33 am
ReefingHavoc wrote:Problem solved. I realized that I was using an outdated WiFi utility and instructions. Once I used the latest utility was easily able to get the ball rolling.
Awesome. glad you got it working.
