Jebao Extension Cable
Posted: Wed Jul 24, 2013 8:52 am
by cjrudy
With my relay box in the basement near my sump and the WP40 controller on the display tank, any ideas on how to get it connected. The cable off the WP40 is only 160cm (about 5ft). That will never reach to connect to the relay box with the Jebao cable.
Someone must be having the same issue. Any ideas ?
Re: Jebao Extension Cable
Posted: Wed Jul 24, 2013 8:55 am
Extend the dimming cable of the harness
Posted: Wed Jul 24, 2013 9:07 am
by cjrudy
rimai wrote:Extend the dimming cable of the harness
Ah, ok, so the only thing I would run into the basement would be the dimming cable, good idea.
Do you have anything thing that would work or would I need to find some cable ?
Posted: Wed Jul 24, 2013 9:13 am
Any cable works...
You can use CAT5 which is readily available.
Posted: Wed Jul 24, 2013 9:29 am
by cjrudy
Ok, thanks,
Is easy to rewire the end connectors ?
Posted: Wed Jul 24, 2013 12:56 pm
by Sacohen
I wouldn't re-wire the end connector, but splice in a piece of cable the length that you need.
Posted: Wed Jul 24, 2013 1:00 pm
by johniii
+1 either solder and heat shrink the splices. Or use gel connectors like a phone line
Sent from my DROID RAZR
Posted: Wed Jul 24, 2013 1:05 pm
by Sacohen
johniii is correct. I mean to put that too, but got busy and had to leave.
Posted: Thu Jul 25, 2013 5:35 am
by cjrudy
Thanks everyone
Posted: Mon Aug 12, 2013 12:58 pm
by cjrudy
rimai wrote:Any cable works...
Just wanted to say thanks for the suggestion Roberto. I ran cat6 cable from the controller in the basement up to the first floor and spliced in the Jebao harness for my two pumps, one wp25 and one wp40
Everything's coded and working great.
