ATO float switches
- Sacohen
ATO float switches
When I have my float switch plugged into the ATO High port and the float is down or IsActive should it read On or Off on the Andriod App and the Portal? Both of them read as "ON".
- Contact:
Re: ATO float switches
Yes if it IsActive, then it should be reading ON. So it is reading and displaying correctly.
http://forum.reefangel.com/viewtopic.php?f=7&t=240
That's just about everything you will want to know about the ATO switches, including pictures.
- Sacohen
Thanks Binder. I've read that a couple of time and I still get confused about it a bit. I don't know why?
- Contact:
No worries. I wrote it and I still get confused. It took me a while to write it and lots of questions to Roberto as well.Sacohen wrote:Thanks Binder. I've read that a couple of time and I still get confused about it a bit. I don't know why?
