REALLY NEED HELP FAST
simplefound
Post by simplefound »
Got in tonight and clicked the button on the controller to see what temp the tank is at, and the screen did not come on.
This has happened before, so i turned the reef angel off at the socket and back on again, now the power light comes on but nothing else, i use this to control my lights among other things and they are now not on.
i have re-flashed it with my files and the status light comes on like normal but still no display or power to any outlets
Thanks in advance
Simon
Re: REALLY NEED HELP FAST
If I understood correctly, the controller is accepting codes, right?
Can you post the code you uploaded?
simplefound
Hi rimai yes it will accept a code, will post it underneath
i have opened the controller and there is some corrosion on some of the leg to the chips, i have done my best to clean this off and now have some maybe all the outlets working but still no screen i am going to assume the corrosion in the controller is the problem.
is there any way i can see the time the reef angel has without the screen?
code:
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit;
InternalMemory.OverheatTemp_write( 950 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardATO( Port1,60 );
ReefAngel.StandardLights( Port2,10,45,23,40 );
ReefAngel.StandardLights( Port3,23,0,11,0 );
ReefAngel.StandardFan( Port4,793,797 );
ReefAngel.WavemakerRandom( Port6,60,100 );
ReefAngel.StandardHeater( Port7,788,792 );
ReefAngel.PWM.SetDaylight( PWMSlope(12,0,22,30,0,100,60,0) );
ReefAngel.PWM.SetActinic( PWMSlope(11,0,23,30,0,100,60,0) );
Yes, you must enable wifi though.
Add this to your setup() section:
ReefAngel.AddWifi();
Then, you can use the Serial Monitor to get the date/time of the controller.
Open Serial Monitor and make sure you have baud rate 57600 and both CR & NL.
Then type "GET /d "
Make sure there is a space after the d
