Help with salinity ATO using water level expansion
Posted: Fri Aug 02, 2013 7:08 am
by dazza1304
Hi Guys, I have had this working well for a while but want to refine it.
Currently I have basically 2 containers - 1 with salt water and the other with RO water.
I currently use the waterlevel ato function to top up salt water and a salinity measure to top up RO.
These work independently of each other which is for the most part fine, but what happens occasionally is, my skimmer section of my sump might overfill a bit if for example the water level expansion (salt water) has just topped up to "40" and then the salinity is low and so RO water is added.
I have posted my code below for this.
What I would like to do, is change the following -feel free to come up with other suggestions as I may be looking at this wrong!!
1. Only enable waterlevelATO (saltwater) function if my salinity is <33.1ppt
2. Only enable RO top up if water level <40.
I think what i need to do is add the below:
if (SalCompensation<33.1)
ReefAngel.WaterLevelATO(Port2,180,35,40);
and
if Reefangel.WaterLevel.Getlevel () <= 40
ATOEnabled=true;
ATOPumping=false;
Is this correct???
Your help as always is appreciated!!
unsigned long lastLowSal=now();//salinity >35.1 timer
boolean SALduration=true;//salinity >33.1 for 2 minutes flag
boolean ATOEnabled=false;//enable ATO function for 5 seconds
boolean ATOPumping=true;//disable ATO function for 5 minutes
unsigned long ATOStart=now();//ATO 5 sec run timer
double Salinitytest;
InternalMemory.OverheatTemp_write( 260 );
InternalMemory.SalTempComp_write( 255); // Change this to compensation temperature
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Timer[1].SetInterval(1800); // 30 mins before reactivation of ATO
//ReefAngel.Relay.DelayedOn( Port3,5 );//skimmer delay on switching on
ReefAngel.StandardHeater( Port6,252,255 );
ReefAngel.StandardFan( Port7,255,258 );
ReefAngel.WaterLevelATO(Port2,180,35,40);// Salinty top up to keep water level correct
// Apply Salinity temp Compensation & salinity calibration
double SalCompensation;
if (ReefAngel.TempSensor.unit)
SalCompensation=ReefAngel.Params.Salinity/(1+((ReefAngel.Params.Temp[T3_PROBE]-InternalMemory.SalTempComp_read())*0.0022));
SalCompensation=ReefAngel.Params.Salinity/(1+((ReefAngel.Params.Temp[T3_PROBE]-InternalMemory.SalTempComp_read())*0.001165));
SalCompensation=round(SalCompensation);
// For displaying salinity without temp compensation
Salinitytest=SalCompensation;
///// If salinity >33.1 for 120 sec set SALduration flag
if (SalCompensation<331) lastLowSal=now();
if (now()-lastLowSal>120) SALduration=false;
if (SALduration && ATOPumping)//if salinity>33.1 for 2 minutes enable ATO
{ATOStart=now();
ATOEnabled=true;
ATOPumping=false;
if (now()-ATOStart<5)//ATO pump on time 5 seconds
if (ATOEnabled) ReefAngel.Relay.On(Port1);
ReefAngel.Timer[1].Start();//start 5 minute disable of ATO
ReefAngel.Relay.Off(Port1);
ATOEnabled=false;
if (ReefAngel.Timer[1].IsTriggered())//after 30 minute disable, enable ATO
ATOPumping=true;
ATOStart=now();
SALduration=true;
///// if skimmer cup full, turn off skimmer
bitClear(ReefAngel.Relay.RelayMaskOff,2);
else {
bitSet(ReefAngel.Relay.RelayMaskOff,2);
ReefAngel.Portal( "dazza1304" );
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 10, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 10, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,15,46, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,39,46, ReefAngel.Params.Salinity );
//map of adc temp comp salinity
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,15,63, "SAT:" );
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,39,63, (int)Salinitytest );
// ORP
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,75,46, "ORP:" );
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,99,46, ReefAngel.Params.ORP );
// Water Level
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,75,63, "WL:" );
ReefAngel.LCD.DrawText( COLOR_BLACK,DefaultBGColor,99,63, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawOutletBox( 12, 79, TempRelay );
// Relay Expansion
Re: Help with salinity ATO using water level expansion
Posted: Fri Aug 02, 2013 9:22 am
by Sacohen
This is something I was thinking of doing too, but didn't know where to start.
Following along.
Posted: Fri Aug 02, 2013 11:18 am
I think it is correct.
Posted: Fri Aug 02, 2013 11:22 am
The logic looks good. I can't comment on the use / values of the salinity variable, but it looks like it would work...
Posted: Wed Aug 07, 2013 3:59 am
by dazza1304
Hi Guys, I have changed things around a lot to try to simplify, but it is not behaving as I expect - code below.
Basically, compiles OK, and after loading, with waterlevel > 40 and salinity <33.1, my RO pump (pump 1) starts, which it shouldn't.
I have probably got something slightly wrong, but cant see where, so your help would be appreciated!!!
if (now()-lastLowSal>120) SALduration=true;
//if salinty >33.1 and waterlevel <=35, top up with RO water
if (SALduration=true && ReefAngel.WaterLevel.GetLevel ()<=35)
ReefAngel.WaterLevelATO(Port1,180,35,40);
SALduration=false;
//if salinty <33.1 and waterlevel <=35, top up with salt water
if (SALduration=false && ReefAngel.WaterLevel.GetLevel ()<=35)
Posted: Wed Aug 07, 2013 4:45 am
Need the rest of your code. I don't see anything obvious here...
Posted: Wed Aug 07, 2013 7:26 am
by dazza1304
Sorry,
here you go!!
unsigned long lastLowSal=now();//salinity >33.1 timer
boolean SALduration=false;//salinity >33.1 for 2 minutes flag
// Ports that are always off
ReefAngel.Relay.Off( Port1 );
ReefAngel.Relay.Off( Port2 );
SALduration=false;
else {
int x,y;
// Salinity
// ORP
// Water Level
// Relay Expansion
Posted: Wed Aug 07, 2013 8:35 am
Your code has no way to stop either port1 nor port2.
You need something like this:
SALduration=false;
ReefAngel.Relay.Off(Port2);
Otherwise, if the SALduration changes state, WaterLevelATO never gets called and that's what causes the port to stay in the previous position.
Posted: Wed Aug 07, 2013 9:29 am
by dazza1304
Hi Roberto,
Tried that, but things dont seem to be happening correctly.
First, after uploading code below, with salinity at 32.9 and wl at 42, nothing happens as would expect.
To simulate operation, then raised wl sensor up until wl less than 35, and then straight away, red status light comes on - go in and execute ATO clear, come back out to main screen - try raising wl sensor until wl less than 35, then port 1 is activated (should be port 2!! according to my reading of the code) and this operates until wl =40.
Again, if I then try raising wl sensor again so wl <35, ATO flag is set again as above?
Can you make any sense of this??
ReefAngel.WaterLevelATO(Port1,30,35,40);
SALduration=false;
ReefAngel.WaterLevelATO(Port2,30,35,40);
else {
int x,y;
// Salinity
// ORP
// Water Level
// Relay Expansion
Posted: Wed Aug 07, 2013 9:41 am
I think it is this:
It will only be true is wl is less and equal to 35
But your ATO function ReefAngel.WaterLevelATO(Port1,30,35,40);
calls for pump water from 35 to 40.... Well, it will never reach 40 to stop the ATO from pumping and clear the timeout.
You should use Serial.print to debug your code... It will make things a lot easier to understand.
Posted: Wed Aug 07, 2013 9:59 am
by dazza1304
rimai wrote:I think it is this:
Thanks Roberto - silly question now, how do I use serial.print? Is there a guide somewhere?
I know you suggested previously on one of my posts to use it, but never got to grips with it!
Posted: Wed Aug 07, 2013 11:14 am
by dazza1304
Actually looked at this a bit more, and it seems according to the arduino website, that the<= operand should be ok.
I think the problems is using the ATO function - can you remind me where I can find the code for it please?
I think I will make my own code for the function to be sure it functions as I require.
Posted: Wed Aug 07, 2013 1:11 pm
The reason the <= is not ok in this situation is because once your Water Level reaches 36% then the ATO would be disabled and never reach 40%. This will also cause the WaterLevelATO to leave the port in a potentially on or off state and not what you want...
You will need to set a flag if the waterlevel reaches less than 35% and then do your if with the flag. Once the water level reaches your desired amount you would then reset the flag.
Posted: Thu Aug 08, 2013 1:02 am
by dazza1304
lnevo wrote:The reason the <= is not ok in this situation is because once your Water Level reaches 36% then the ATO would be disabled and never reach 40%. This will also cause the WaterLevelATO to leave the port in a potentially on or off state and not what you want...
Thanks Lee, yes I understand now - I thought once the ATO function was called it looked after itself so to speak, but obviously not.
I will write my own code for this which should be pretty simples - I hope!
Will post up my code once I have sorted!
Thanks again,
Daryl
Posted: Thu Aug 08, 2013 7:31 am
by dazza1304
Have redone the code now, without the waterlevel ATO function and all seems to work fine!!
boolean SALduration=false;//salinity >33.1 2 minute debounce
unsigned long lastLoWat=now();//WL < 35 timer
boolean Watduration=false;//WL <35 2 minute debounce
boolean ROtopup = false;
boolean SALTtopup = false;
// If salinity >33.1 for 120 sec set SALduration flag;salinity debounce
///// If WL < 35 for 120 sec set Watduration flag;Waterlevel debounce
if (ReefAngel.WaterLevel.GetLevel()>35) lastLoWat=now();
if (now()-lastLoWat>120) Watduration=true;
//if salinty >33.1 and waterlevel <35, top up with RO water until WL =40
if (SALduration==true && Watduration==true) ROtopup=true;
if (ROtopup==true) ReefAngel.Relay.On(Port1);
if (ROtopup==true && ReefAngel.WaterLevel.GetLevel()>40)
ROtopup=false;
SALduration=false;
Watduration=false;
//if salinty <33.1 and waterlevel < 35, top up with SALT water until WL = 40
if (SALduration==false && Watduration==true) SALTtopup=true;
if (SALTtopup==true) ReefAngel.Relay.On(Port2);
if (SALTtopup==true && ReefAngel.WaterLevel.GetLevel()>40)
SALTtopup=false;
Watduration=false;
else {
int x,y;
// Salinity
// ORP
// Water Level
// Relay Expansion
Posted: Thu Aug 15, 2013 3:17 am
by dazza1304
Hopefully someone will be able to help!!
THought all was working fine, but I have actually caught the unit operating relay 2 when salinity > 33.1 and water level > 35.
I cannot see how this is possible from my code.
Can someone have a look and see what might be going on please??
ROtopup=false;
SALduration=false;
Watduration=false;
SALTtopup=false;
Watduration=false;
else {
int x,y;
// Salinity
// ORP
// Water Level
// Relay Expansion
Posted: Thu Aug 15, 2013 8:20 am
You are only turning port2 off when it reaches 40:
Posted: Thu Aug 15, 2013 8:37 am
by dazza1304
Thanks Roberto, but that's what I want it to do.
So basically I have 2 flags for salinity and water level.
If salinity <33.1 AND water level <35, then I top up with saltwater until water level > 40, then turn off port.
If salinity >33.1 AND water level <35, then I top up with RO water until water level> 40, then turn off port.
I can't see how with my code it is possible for port 2 (saltwater top up) to be turned on with salinity > 33.1 and water level level > 35?
I have seen this happen whilst watching it - what alerted me to this was my salinity started to rise.
Any ideas?
Posted: Thu Aug 15, 2013 9:23 am
But in your code, you only turn off port 2 when wl is greater than 40....
So, of course it will run when it it greater and 35....
Here is the code that turns off port2:
SALTtopup=false;
Watduration=false;
You can clearly see that the code only turns port2 off when wl is greater than 40
Posted: Thu Aug 15, 2013 9:33 am
by dazza1304
Hi Roberto, maybe Im not explaining myself well, or Im missing something -the latter probably being the case!
Port 2 (saltwater top up) should ONLY be turned on when the salinity <33.1 AND Water level < 35.
Once its on, it then runs until water level> 40, then turns off?
//if salinty <33.1 AND waterlevel < 35, top up with SALT water until WL = 40
Posted: Thu Aug 15, 2013 9:51 am
SALduration==false happens all the time....
So, if the reading is less than 33.1 even for a split second, it will turn port 2 on and it will only turn port2 off when wl>40.
Posted: Thu Aug 15, 2013 9:52 am
Place some Serial.println in your code to monitor debug and see how things are happening.
Posted: Thu Aug 15, 2013 10:07 am
by dazza1304
rimai wrote:SALduration==false happens all the time....
Yes, but Watduration==true will only be true if water level < 35 and thus port 2 should only turn on if both conditions are met?
I am more than happy to try to debug myself, but dont know how to use the Serial.println. I know you tried to explain once, but you lost me to be honest!! If you could point me to a relevant post or tutorial I will see what I can do!!
Posted: Thu Aug 15, 2013 10:29 am
Yes, but if wl was <35 and salinity blipped below 33.1 for a micro second, it would turn port2.
Here is some resource for serial debugging:
http://www.ladyada.net/learn/arduino/lesson4.html
http://my.safaribooksonline.com/book/ho ... rom_arduin
RA uses 57600 baud rate.
Posted: Fri Aug 16, 2013 9:31 am
by dazza1304
Got it!!
I understand now - guess its a good idea to "debounce" sensor inputs - I had done this for the water level and salinity high, but not salinity low.
Anyway, re done my code, as I figured I only want to trigger the debounce for salinity high and low when my water level is low.
Anyway, here is my updated code, which works fine!
unsigned long lastHighSal=now();//salinity <33.1 timer
boolean SALdurationHigh=false;//salinity <33.1 2 minute debounce
if (Watduration==true)
if (SalCompensation>331) lastHighSal=now();
if (now()-lastHighSal>120) SALdurationHigh=true;
lastLowSal=now();
lastHighSal=now();
ROtopup=false;
SALduration=false;
Watduration=false;
if (SALdurationHigh==true && Watduration==true) SALTtopup=true;
SALTtopup=false;
Watduration=false;
else {
int x,y;
// Salinity
// ORP
// Water Level
// Relay Expansion
Posted: Fri Aug 16, 2013 9:45 am
Awesome!!!
