PWM to Analog
Posted: Sat Aug 03, 2013 8:04 pm
by jedimasterben
Hello all,
I have a PWM RA. My relay box has the jumper inside to switch Analog/PWM, like this:
(that's where the jumpers started off at)
I don't believe that the PWM has the extra circuitry to do analog, as well, or does it? And if it does, I just move the jumpers to 2 and 3 on both instead of 1 and 2?
I want to control my two Tunze pumps and don't want to have to have another relay box
Re: PWM to Analog
Posted: Sat Aug 03, 2013 10:24 pm
Yes, the label is actually wrong.
Should be PWM/Analog.
So, if you move them to 2-3, you will change the signal to analog.
Re: PWM to Analog
Posted: Mon Aug 05, 2013 8:15 am
by jedimasterben
rimai wrote:Yes, the label is actually wrong.
AWESOME! So do all RA now have this and future users don't have to choose between the PWM/0-10v?
I'm so happy - now I can control my two Tunzes directly and get rid of my controller I just bought for them... LOL
Re: PWM to Analog
Posted: Mon Aug 05, 2013 8:24 am
Only relay boxes Rev 8.1 can do that.
Re: PWM to Analog
Posted: Mon Aug 05, 2013 10:06 am
by jedimasterben
rimai wrote:Only relay boxes Rev 8.1 can do that.
Of course, but I'd imagine only 8.1 will be sold going forward.
Re: PWM to Analog
Posted: Mon Aug 05, 2013 10:32 am
Yes
Re: PWM to Analog
Posted: Thu Aug 15, 2013 4:00 pm
by jedimasterben
Ok, so I have the jumpers set to 2/3 on both of the sets of pins. I have the code inserted in my RA to control both channels, and I'm measuring the voltage change as the RA sends out the 0-10v signals, but the powerheads are not responding. I thought maybe my wiring was backwards (pins 4 and 5 on the DIN connector), so I flipped it around, and they still won't change from 100%. When I plug the Tunze 7096 controller back in to them, they cycle up and down.
Any ideas? I'm measuring the voltage going all the way to the pins on the DIN connector, so the voltage is getting to the powerheads' little control box bits.
Re: PWM to Analog
Posted: Thu Aug 15, 2013 4:10 pm
I think it is 1-2 and not 4-5
Re: PWM to Analog
Posted: Thu Aug 15, 2013 4:11 pm
by jedimasterben
I was going by this post here:
rimai wrote:tunze pinout.png
Tunze pinout
EDIT: sorry, the quote didn't work right. This post:
http://forum.reefangel.com/viewtopic.php?p=2616#p2616
Re: PWM to Analog
Posted: Sun Aug 18, 2013 11:18 am
by jedimasterben
Do you think that the PCB could be properly labelled, and it was already set to Analog?
Re: PWM to Analog
Posted: Sun Aug 18, 2013 10:12 pm
I found that tunze pinout on google. The original author may have it wrong.
The picture above is set to PWM signal. As I said in the previous post, the label is inverted. It should be PWM/Analog instead of Analog/PWM.
The rev 8.1 of the relay box is soon to be no more, so there is no point of changing/correcting anything.
Re: PWM to Analog
Posted: Mon Aug 19, 2013 6:16 am
by jedimasterben
Ok, just checking on that.
Do you know which pins the Tunze cable for the RA uses?
Re: PWM to Analog
Posted: Mon Aug 19, 2013 8:11 am
Re: PWM to Analog
Posted: Mon Aug 19, 2013 8:12 am
by jedimasterben
And that is the missing link! You're the man, Roberto!
Re: PWM to Analog
Posted: Tue Aug 20, 2013 4:08 pm
by jedimasterben
Well, sat down to make that change and... no dice. Wired it exactly like yours above (mine is different since it is prewired, but I used a multimeter to confirm continuity.
Tried it with two different wires and two different Tunzes, and both had no change in their speed (controller is currently at 63 and 76%, and output voltage is spot on).
