RF Expansion Module
porksmash
Re: RF Expansion Module
Post by porksmash »
No, I don't have it yet. I'm trying to see if it has the features I would like. To be honest I won't be integrating it with a ReefAngel controller, it'll be my own Arduino controller. I may just interface my Arduino directly with the wireless module now that I look at it, though. Thanks for the info!
JNieuwenhuizen
Post by JNieuwenhuizen »
Roberto, is it still only custom mode that can be used for anti-sync? My MP60s are on either end of my tank
I use anti-sync on all the time.
Just press the mode button on your vortech driver.
That's a feature of the driver and not the controller.
reefcycle
Post by reefcycle »
ok so I am finally taking a stab at setting up rf. rf is a feature in ragen and I set values to 855 856 857 in the internal memory. I then go into arduino and open vortechsetup and load it and all I have is solid green led on module. p.s. I jumped the two jumpers as stated in the instructions. basically I cant get the rf to blink
Did you have the RF module connected before uploading the code?
If not, you will need to reboot the controller and the RF should start blinking.
reefcycle
Post by reefcycle »
Plugged in and solid green. Prior to jumping the 2 leads it blinked purple. After leads jumped solid green. Uploaded code successful and stayed solid green.
P.s. also power cycled multiple times in attempt to do it
Do you have "Assigning Slaves" on the LCD screen?
reefcycle
Post by reefcycle »
I'm @work at the moment but it did not say that last night
reefcycle
Post by reefcycle »
at home I try again
no pump assigning slave mode
reefcycle
Post by reefcycle »
Any ideas?
What do you get on the LCD screen when you load the VortechSetup code?
reefcycle
Post by reefcycle »
Nothing but normal display
Are you sure you are uploading the correct code and it is being sucessfully uploaded?
File->Sketchbook->Example Codes->VortechSetup
reefcycle
Post by reefcycle »
verbatim
Please post the results of your upload.
I think the code is not being uploaded if you are getting the normal display.
reefcycle
Post by reefcycle »
Binary sketch size: 21274 bytes (of a 32256 byte maximum)
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM8 -b115200 -D -Uflash:w:C:\Users\ADMINI~1\AppData\Local\Temp\build2240262763879693884.tmp\VortechSetup.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         System wide configuration file is "C:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM8
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude done.  Thank you.
I saw it said com8 so I switched to com8
now
avrdude: Recv:
reefcycle
Post by reefcycle »
kk here it is on com 5 and restarting comp and rebooting ra
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM5 -b115200 -D -Uflash:w:C:\Users\ADMINI~1\AppData\Local\Temp\build2623433807375842426.tmp\VortechSetup.cpp.hex:i
         Using Port                    : \\.\COM5
avrdude: Recv:
reefcycle
Post by reefcycle »
Double check... two jumpers only right. Not three. ?
All three need to be there.
One was already placed, which is for the reset and the other 2 are for the expansion.
reefcycle
Post by reefcycle »
ok so all three ports in uploaded seemed to really take long time for upload and then nothing blinking again
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM5 -b115200 -D -Uflash:w:C:\Users\ADMINI~1\AppData\Local\Temp\build8703106588888654215.tmp\VortechSetup.cpp.hex:i
avrdude: Recv:
reefcycle
Post by reefcycle »
Any ideas?
That is still not uploading.
You see a whole bunch of stuff on the status area and the red led status blinks when it does upload.
reefcycle
Post by reefcycle »
I think its working. Switched com ports again
reefcycle
Post by reefcycle »
Ok so rf expansion code uploaded slaves assigned and now I am reading reading reading and having hard time comprehending how the actual modes change via mobile android app. so confused lol I will get this I swear!@ rf mode speed and duration speed I read is a number 0-255 but what value for mode and duration
Open the app and hit the menu button.
Choose Memory
Choose RF Mode
Enter the number of the mode you want:
#define Constant 0
#define Random1 1 // Lagoonal
#define Random2 2 // Reef Crest
#define ShortWave 3
#define LongWave 4
#define Smart_NTM 5 // Nutrient Transport Mode
#define Smart_TSM 6 // Tidal Swell Mode
Appleseed
Post by Appleseed »
Hi,
Im new to this so excuse my noobness...
Anyhow i have mine set as follows;
ReefAngel.RF.SetMode(Random2,50,15);
It seems that only the sync pumps follows the setting, the pumps in anti-sync mode seem to be running at a constant speed, also what does the duration function for random2 do?
cheers.
Andy
The duration is not used for that mode.
I was never able to get anti-sync on my pumps on those modes.
I guess there is some issue with drivers being of different versions or something else.
Appleseed
Post by Appleseed »
thanks Roberto.
alexwbush
Post by alexwbush »
I see the code to control vortechs during a cloud/storm mode. Am I missing the code to add clouds to the radion?
http://forum.reefangel.com/viewtopic.php?p=13002#p13002
Try this and let me know how it works out.
