Sketch too big...
Posted: Mon Aug 12, 2013 4:44 pm
by jedimasterben
So I have the standard RA, with the Salinity expansion, Wifi attachment, and switched my relay box to send a 0-10v signal to control my two Tunze powerheads.
Here is my code:
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port4Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardLights( Port3,20,0,14,0 );
    ReefAngel.DosingPumpRepeat( Port4,0,60,125 );
    ReefAngel.DCPump.SetMode( ReefCrest,100,10 );
    ReefAngel.Portal( "jedimasterben" );
    int x,y;
    // Parameters
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,49,66, "SAL:" );
    ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.Salinity,COLOR_DARKKHAKI,73,66, 10 );
    // Main Relay Box
    // Date and Time
By having a single expansion and one attachment, have I really filled the memory capacity? Is that all it takes? My code is exactly what the RA Wizard spits out, installed from the latest 1.0.9 installer.
Re: Sketch too big...
Posted: Mon Aug 12, 2013 4:55 pm
It's the DCPump class...
It is huge because it has to store all wave patterns in the memory, so you can switch to which one you want at will.
If you choose to use the old method of wave pattern, you most likely can fit the code, but you would be limited to one wave pattern only.
http://forum.reefangel.com/viewtopic.php?f=14&t=2895
Posted: Mon Aug 12, 2013 5:03 pm
by jedimasterben
Gotcha, just didn't expect that to throw it overboard on the size.
Ok, so if I want to run only Reef Crest mode, then I need to put this:
ReefAngel.PWM.SetDaylight( ReefCrestMode(70,30,true) ); // ReefCrest at 70% +/- 30% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(70,30,false) ); // ReefCrest at 70% +/- 30% on anti-sync mode
between these:
Redid the sketch with that in place, and it is 31,336 bytes (of a 32,256 byte maximum) LOL, can't cut too much closer than that!
Posted: Mon Aug 12, 2013 5:22 pm
by bencollinz
you don't need to draw the outlets if they're defaulted to on. I rarely look at the RA's screen for anything. my phone for everything.
