Relay Stuck On
Posted: Fri Apr 22, 2011 10:15 am
by uclamatthew
I'm not sure if this is a hardware or software question, but the relay I've designated for my metal hallide lights is stuck on. The controller shows that the relay should be off, but it is definitely not. I'm using Curt's latest libraries & RAGen with no modifications to the code generated. Any ideas, or where to start looking?
Re: Relay Stuck On
Posted: Fri Apr 22, 2011 4:08 pm
by binder
It could very well be a relay that is damaged/broken. That has happened before. Roberto should be able to shed more light on the topic.
Re: Relay Stuck On
Posted: Fri Apr 22, 2011 8:00 pm
It may be bad relay.
You got PM.
Re: Relay Stuck On
Posted: Wed Aug 17, 2011 9:59 pm
by sfboarders
Hey Roberto, I have a relay/socket that is stuck ON and no longer using the timer. I'm using Curts RAGen. Lmk if you need any additional information.
Re: Relay Stuck On
Posted: Thu Aug 18, 2011 8:04 am
What were you using that socket for?
It could be it went bad.
Re: Relay Stuck On
Posted: Mon Aug 22, 2011 5:45 am
by mbertalha
I'm with this problem on the second outlet, such as replacing the relay?
tanks
Marcelo
