Relay Expansion Module
Posted: Thu Aug 15, 2013 4:14 pm
by clw143
Does adding a relay expansion module and relay box give you 2 additional PWM ports?
Re: Relay Expansion Module
Posted: Thu Aug 15, 2013 5:04 pm
Nope, but if they are different you can swap with your main relay box.
Posted: Thu Aug 15, 2013 5:24 pm
by clw143
That seem like an opportunity for you all to expand on
Posted: Thu Aug 15, 2013 5:29 pm
Not sure what you mean, but technically its not possible as the expansion bus is only 4 wires and no way to talk to the pwm ports and control the relays on that bus.
Posted: Fri Aug 16, 2013 7:32 am
by Sacohen
clw143 wrote:That seem like an opportunity for you all to expand on
It's been brought up before, but as lnevo said it a hardware limitation although it would be nice to have use of the additional PWM ports. the system is always changing and updating so who knows what the future entails.
