Salinity dropping and rising by 6ppt during the day & night.
Posted: Fri Aug 16, 2013 12:27 pm
My Salinity meter is reporting strange levels.
As you can see in the attached shot from the portal it is rising and dropping through the day and night by around 6ppt.
My water level is stable around 32% and is being maintained by RO/DI water with Kalkwasser mixed in it.
Right now the ATO code in my RA is being by passed because it seemed to be going on at time when it was not directed to (different issue) so I have been manually turning it on and off from work or where ever thru my phone of internet.
I thought there was an issue with the probe because if I re-calibrated it the levels would got back to where they should be (around 35-36ppt) and a hydrometer seems to reflect the equivalent SG levels, but I did not re-calibrate the probe yesterday and as you can see the Salinity jumped from 32ppt to 38ppt at around 1am and then back down from 35ppt to 30ppt at 1pm this afternoon.
1am and 1pm is the time that my de-nitrification chamber dumps water back into the sump from the chamber, but it also does it at 7am and 7pm and there are no drastic changes in Salinity at those times.
Any suggestions or help appreciated.
