Jebao Tuning
clw143
Jebao Tuning
Post by clw143 »
I searched around and saw people talking about doing it but I can't find it.
How would I code to do millis tuning through the portal?
Re: Jebao Tuning
I've seen this post for days now and I don't have the exact answer, because I never got the hang of the new DCPump command, but I think this will get it going.
Make sure that the
is in your features.
Then add this code to tell the pump to use the portal for it's setting.
or Actinic if it is plugged into the Actinic port.
If it is on the Expansion Ports then I think the code is
ReefAngel.DCPump.ExpansionChannel[0] = true;
Then I think you can just go to the portal and adjust the settings under the Internal Memory > DC Pump (Jebao/Tunze)
