Moonlight dimming interfering with daylight channel
Posted: Mon Aug 19, 2013 11:04 am
by Smokieroom
I have Steve's LEDs so my daylight and actinic drivers both go to one power supply so only one power plug. I would like to use the internal memory for my dimming control and it works but I have a problem with the moonlight dimming. I have it programed through the portal for daylights on at 12:00 off at 20:00 the actinic on a 30 min offset. So my actinic channel starts at 0% at 11:30 and ramps up over 60 mins just fine but I want my daylights to start a 0% at 12:00 and ramp up over a hour. The moonlight feature is active during that time so my daylight channel is starting at say 60% at 11:30 then dropping to 0% at 12:00 to start ramping up. Is there a way to disable the moonlight in the internal memory during the the period from 11:30 to 12:00 so my daylights will stay at 0%?
Re: Moonlight dimming interfering with daylight channel
Posted: Mon Aug 19, 2013 3:54 pm
I don't follow.
Can you post your code?
Posted: Mon Aug 19, 2013 4:28 pm
by Smokieroom
Here is my code. I think the problem may be with what is stored in the internal memory is there a way to pull that off the controller?
ReefAngel.FeedingModePorts = Port2Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port1,11,30,21,0 );
ReefAngel.StandardHeater( Port3,775,778 );
ReefAngel.SingleATO(true,Port4,60,0);
if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port4);
ReefAngel.DosingPumpRepeat( Port5,0,1440,120 );
ReefAngel.DosingPumpRepeat( Port6,720,1440,30 );
ReefAngel.StandardFan( Port8 );
ReefAngel.Portal( "Smokieroom" );
Posted: Mon Aug 19, 2013 5:34 pm
Make sure the end% of both channels is 0%
