WiFi Add-On Stops Updating Client
Posted: Wed Aug 21, 2013 3:45 pm
Howdy,
To begin, I received along with my RA Plus a faulty USB/Com cable. Luckily a few reef society member in my area have RAs also and lent me a spare. I did officially contact RA today with RMA request information.
However, the issue at hand that I cannot resolve is with the WiFi add-on. Specifically that it appears to 'drop' the connection to the Reef Angel client after only a few minutes and the connection doesn't resume.
What I have done on my part:
Scoured the forums here for similar instances.
Un/reinstalled RA Arduino
Flashed the RA to factory settings
Initiated Memory on RA
Upped the WiFi test loop
Ran the Arduino Wizard
Installed/ran ReefAngelWifiUtil.exe
Configured WiFi router WPA2-PSK AES
Set an isolated channel (11) for WiFi
Reserved IP address and port 2000 for RA
Removed RA from router firewall
The RA is on a LAN not connected to the internet, there aren't any other devices on the WiFi, and MAC filtering is on.
Here is the WiFi Settings dump:
Please advise.
CMD
get ip
IF=UP
DHCP=ON
IP=192.168.2.3:2000
NM=255.255.255.0
GW=192.168.2.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
<2.38.3> get w
SSID=belkin.ea3
Chan=0
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=**********
<2.38.3> get u
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
<2.38.3>
