Issues with Feeding Mode code
meadowsad
Post by meadowsad »
I am trying to change my feeding mode code to switch to nutrient transport after feeding and I can't seem to get it to work. Unfortunately I don't think I understand this enough to figure it out...
To start this line works fine for Feeding Mode
ReefAngel.DCPump.FeedingSpeed=30
In the end I would like the Feeding Mode to spin my pumps down to 30% and then do nutrient transport after feeding has completed.
I tried something like this;
   static unsigned long feeding;
       feeding = now();
       ReefAngel.DCPump.SetMode( Constant,30,10 );
  else if (now()-feeding<=3600)
       ReefAngel.DCPump.SetMode( NutrientTransport,100,30 );
This stopped the pumps in Feeding Mode and when that mode ended it went in to NTM but stayed in that mode. The pumps didn't come back to their original speed.
As a test I have tried removing;
And added;
This code doesn't work, the pumps just stop during feeding. I have tried putting it in the setup function and after the loop function. I'm not sure where this code should go in order for this to work correctly. In the loop function?
Basically I need some guidance here since my coding experience is very very limited. Any help would be appreciated, thanks!
Re: Issues with Feeding Mode code
You said this worked:
So, keep it.
Also, you said this didn't work:
So, remove it.
Give it a shot and keep us posted.
meadowsad
Post by meadowsad »
Ended up using
    feeding = now();
    else if (now()-feeding<=9000)
Without removing the
in the setup function. Not sure if I can remove that now or not but it isn't hurting anything so I will leave it. This is the same thing I did last night, with the line above removed, but maybe I just needed a break :)
You need a final else to go back to the mode you want since you are setting the mode instead of just overriding...
meadowsad
Post by meadowsad »
Do I just put a simple else at the end and that is it?
ReefAngel.DCPump.Mode=whatever you normally use;
You may be having a problem with the setmode because you might have UseMemory=true (default) so it may be reverting to your memory settings.
Anyway try some out and let's see your full code next.
meadowsad
Post by meadowsad »
So this is the code I am using now and it is working great! I verified it goes to the pump setting before feeding at least 3 times.
// Define Relay Ports by Name
#define Tunze1             1  // Tunze 6095 #1
#define Tunze2             2  // Tunze 6095 #2
#define ReturnPump         3  // Laguna 1350 Pump
#define Skimmer            4  // Reef Dynamics INS80 Skimmer
#define AIVega1            5  // Aqua Illumination Vega Color #1
#define AIVega2            6  // Aqua Illumination Vega Color #2
#define Heater             7  // Eheim Jager 250w Heater
#define ATOPump            8  // Aqua Lifter Pump
    ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port8Bit; // Turn off Return Pump, Skimmer, ATO during feeding
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port8Bit; // Turn off Return Pump, Skimmer, ATO during water change
    ReefAngel.LightsOnPorts = Port5Bit | Port6Bit; // Turn on/off Aqua Illumination Vega Color #1 and #2 in Lights On / Off menu
    ReefAngel.OverheatShutoffPorts = Port5Bit | Port6Bit | Port7Bit; // Turn off Aqua Illumination Vega Color #1 and 2 and Eheim Jager Heater on over heat status
    ReefAngel.TempProbe = T1_PROBE; // Use Temp Probe 1 for temperature reading
    ReefAngel.OverheatProbe = T1_PROBE; // Use Temp Probe 1 for over head alert
    InternalMemory.OverheatTemp_write( 830 ); // Over heat status when temperature reaches 83 degrees Fahrenheit
    ReefAngel.Timer[FEEDING_TIMER].SetInterval(600); // Feeding Mode length
    ReefAngel.DCPump.FeedingSpeed=30; // Set Tunze 6095 #1 and #2 to 30% speed
    ReefAngel.DCPump.WaterChangeSpeed=0; // Turn off Tunze 6095 #1 and #2
    ReefAngel.Relay.On( ReturnPump );
    ReefAngel.Relay.On( AIVega1 );
    ReefAngel.Relay.On( AIVega2 );
    ReefAngel.Relay.DelayedOn( Tunze1,1 ); // Delay Tunze 6095 #1 by 1 minute
    ReefAngel.Relay.DelayedOn( Tunze2,1 ); // Delay Tunze 6095 #2 by 1 minute
    ReefAngel.Relay.DelayedOn( Skimmer,1 ); // Delay Skimmer by 1 minute
    ReefAngel.StandardHeater( Heater,780,800 ); // Keep temp between 78-80 degrees Fahrenheit
    ReefAngel.StandardATO(ATOPump,1200); // ATO Pump with 20 minute timout
    // Schedule for Tunze 6095 #1 and #2
    if (hour()>=0000 && hour()<8) // Tunze 6095 #1 and #2 at 30% from 12am-8am
    if (hour()>=8 && hour()<9) // Tunze 6095 #1 and #2 at 50% in Lagoon mode from 8am-9am
    ReefAngel.DCPump.SetMode( Lagoon,50,10 );
    if (hour()>=9 && hour()<20) // Tunze 6095 #1 and #2 at 70% in Reef Crest mode from 9am-10pm
    ReefAngel.DCPump.SetMode( LongPulse,80,10 );
    if (hour()>=20 && hour()<21) // Tunze 6095 #1 and #2 at 50% in Lagoon mode from 10pm-11pm
    if (hour()>=21 && hour()<2359) // Tunze 6095 #1 and #2 at 30% 11pm-12am
    // Run Nutrient Transport Mode after Feeding Mode completes
    feeding = now();
    ReefAngel.DCPump.SetMode( Constant,30,10 ); // Set Tunze 6095 #1 and #2 to 30% speed
    else if (now()-feeding<=30) // Next 30 seconds are in Nutrient Transport Mode(for testing)
    ReefAngel.DCPump.SetMode( NutrientTransport,100,30 ); // Set Tunze 6095 #1 and #2 to 100% speed with 30ms pulse in Nutirnet Transport Mode
    ReefAngel.Portal( "meadowsad" );
Awesome!!
