Wifi Attachment
Snookin
Wifi Attachment
Post by Snookin »
I set up my wifi attachment successfully, but I can only access my reef angel from my phone or computer if I am at my house. If I go out than my parameters will not update even if I am connected to Wifi.
What is the problem?
Re: Wifi Attachment
Port Forwarding.
Snookin
Re: Wifi Attachment
Post by Snookin »
Okay? So how do I set it up to work?
Re: Wifi Attachment
You need to open port 2000 on your router and have it forward to the ip address of your wifi module. Also you may want to check if it's already there. Make sure you point your phone to your external (wan) ip address. If you don't know what that is check whatsmyip.org
Snookin
Re: Wifi Attachment
Post by Snookin »
Does anybody know what Port an Iphone has?
Re: Wifi Attachment
It's not on your phone.
It needs to be setup on your router.
By default, all routers block incoming requests to prevent hackers from invading your network.
You must open a hole in your firewall so the router knows it's you trying to access the controller and not a hacker trying to invade your network.
Here is more info on the subject:
http://en.wikipedia.org/wiki/Port_forwarding
Try using this application. I heard it works well:
http://www.simpleportforwarding.com/
