can not power my controller
Posted: Mon Sep 02, 2013 4:31 am
by ahmed
Hello all
today i received my RA controller i did all steps for
Getting Started
Using your Reef Angel Controller for the first time
1. Insert one end of the communication cable to the communication connector of the controller head unit.
2. Insert the other end of the communication cable to the communication connector of the relay box.
3. Plug the temperature probe to the head unit
4. Plug the pH probe to the head unit
5. Insert the power cord to the power inlet connector of the relay box.
6. Follow all steps and precautions and exercise caution when working with electronic devices near any
source of water.
7. Plug the power cord to the wall outlet.
8. You should now see the green power led on and the preloaded code already running on the LCD screen.
9. Congratulations. You have powered your Reef Angel Controller for the first time.
but unfortunately its not powered on my controller any idea?
Re: can not power my controller
Posted: Mon Sep 02, 2013 1:28 pm
Check all connections and try again.
Also, try the USB power cable. Does it turn on the head unit?
