Different settings for 2 different DC Pumps.
Roberto;
I don't think there is a was to has different settings (speed, duration or offset) for differrent DC pumps.
For example I have a WP-25 and a WP-40. I want the 40 to run cosmith71 ElseMode from the DCPump mode now that lenvo reworked my code to handle the denitrification chamber and ATO settings better.
He set the Jebao pumps to use the DCPump libraries and the portal if I wanted to change them.
My problem is that both pumps are using the same settings.
The WP-40 needs to be set lower than the WP-25.
If I put the setting at a good point for the 40 then the 25 runs to slow and may even stop. (it doesn't like to run below 30%).
lenvo suggested adding a per channel offset to handle mixed pumps.
Anything like this possible?
Thanks;
Re: Different settings for 2 different DC Pumps.
You will need to code the dimming channels independently instead of dcpump class
Sent from my SPH-L710 using Tapatalk 4
Roberto what about a setting for the anti sync channel.. Otherwise its a bit of custom coding for every function etc...
Not with the dcpump class.
It will set the percentage .and apply it inside the refresh () function.
If you use the pwm class, you can set it to whatever you want before it is applied.
The PWM setting is the way I had it before.
change the
So with the DCPump class you can't have different settings, but with the PWM class you can't use the portal to change the modes.
I think I may have found a happy medium for both pumps.
Even though I have them set to Sync and AntiSync they are reading as running the same on the portal and phone.
I did have them working when they were set to true and false, but that was on lnevo's first code, when he fixed some stuff and I re-entered the info for the 2nd pump I can't get them to work in Anti-Sync.
You could still use the portal to change the settings even if you use the PWM class...
But you would have to recreate everything that was already created behind the scenes.
Something like this:
if (InternalMemory.DCPumpMode_read()==ReefCrest)
ReefAngel.PWM.SetActinic(ReefCrestMode(InternalMemory.DCPumpSpeed_read()-30,10,Sync)); // Internal memory Speed minus 30%
ReefAngel.PWM.SetDaylight(ReefCrestMode(InternalMemory.DCPumpSpeed_read(),10,Sync));
And you would have to do this for each mode.
That's what the libraries does behind the scenes.
Thad why the offset should be implemented inside the dcpump class...i'd submit a patch if i had time...
I have an idea how to do this without a lot of code. Let me think on it.
meadowsad
Post by meadowsad »
Any progress on this? :)
This is exactly what I was trying to do with my Tunzes a month or so ago. I wanted one running LongPulse and one running Constant. I ended up getting this working but it felt very cobbled together lol.
It would be awesome if we could have the channels performing at different speeds or even different wave patterns while still using the dcpump class.
Would be impossible to have them use dcpump class and be in two different modes. Speed is one thing...that would have been an offset. I forgot my idea and havent had time to work on this.
You could do what your asking but one pump would not be able to use the dcpump class. You could base the independent pump on the settings for dcpump though...
Anything new on this front?
Lee you said you may have an idea, but I know you have very little time and may have not gotten to it.
Looking at the code, it would be very complicated without a complete overhaul with how it's being done.
I would recommend at this point in time, to do it manually without the DCPump class if you need this functionality.
I don't need it, but it's one of those things that would be nice to be able to do.
I know a couple of others have asked about it too.
My setup is working fine.
I think I can do something and it would greatly simplify the code, but I don't have a DCPump and no way to test it. If someone is willing to try it, I can put up a patch...
I'll try it since I'm the one asking for it.
Ok, Steve, you ask and you shall receive.
You can activate the offset for the AntiSync channel by specifying the percent power of the other channel by using a statement like this:
    ReefAngel.DCPump.AntiSyncOffset=75;
This is a percent, so if you were at Constant 100, the Sync channel would be 100 and the AntiSync would be 75.
If you were at Constant 50, the Sync would be at 50 while the AntiSync would be at 37.5 (whatever that rounds to as a byte)
Download the branch from here
I basically cleaned up all of the case statements for each mode. It should make adding a new modes much easier. just set the Sync and AntiSync speeds accordingly and at the end of the case statement it will now call ReefAngel.SetDCPumpChannels(byte SyncSpeed,byte AntiSyncSpeed) which will apply the DCPump.Threshold and the AntiSyncOffset to the speeds and write to the proper channels. There is now also one function that writes the speed to the channel which will make it much easier to add future channels to the list. It should also make adding future channel modes easier, like back-wall or something :)
Let me know if you have any questions. This compiles for me and I have confidence that it should work.
Thanks a lot Lee.
I'll try it tonight or over the weekend.
I downloaded the libraries and replaced my previous version of them.
1st of all when I check the Library version it stall reads 1.1.0. Is this a change to 1.1.0 or 1.1.1?
2nd the ReefAngel.DCPump.AntiSyncOffset=75; goes in the setup section.
I put it here...
ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
It seems to compile fine until it gets to the point of the random wave mode.
I get the following error "expected unqualified-id before numeric constant"
// Add Else Mode definition..
const int Else=16;
The error message came up when I was trying out the new libraries to test the DNS server.
So it's not related to what you modified for the DCPump Offset.
There is something in (or noti in) the libraries on GITHub that seems to be causing a problem with the Else Mode definition for the Random wave modes.
ElseMode is now built in. :)
You can take out the const int and the ElseMode function you have in your code.
Ok so just remove all the code for Else Mode?
Yep
As you know i don't know about coding.
I finally got my code to a point where it won't give me errors prior to the compiling when I remove the Else Mode Code.
It will check everything add then do the compiling and return a message that says
"Error Compiling" at the end.
#include <Wire.h>fF
#include <RA_NokiaLCD.h>f
// Define Relay Ports by Name
#define Actinic_Lights     1
#define Day_Lights         2
#define Kalkwasser         3
#define Pumps              4
#define Sump_Fan           5
#define DeNit_Doser        6
#define DeNit_Pump         7
#define ATO_Pump           8
#define Unused             Box1_Port1
#define Feeder             Box1_Port2
#define Unused             Box1_Port3
#define Unused             Box1_Port4
#define Unused             Box1_Port5
#define Unused             Box1_Port6
#define Unused             Box1_Port7
#define Dummy              Box1_Port8
// Does not need to be global.
// unsigned long ATOUpdate=0;
//Set Standard Menu
ReefAngel.AddStandardMenu();
ReefAngel.DCPump.AntiSyncOffset=85;
ReefAngel.Relay.On( Pumps );
ReefAngel.Relay.On( Dummy );
  ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
  ReefAngel.StandardLights( Day_Lights,13,0,21,0 );
  ReefAngel.StandardLights( Sump_Fan,13,0,21,0 );
  ReefAngel.WaterLevelATO(ATO_Pump,720,28,31);
  if ( hour()>=13 && hour()<21 )
  ReefAngel.PWM.SetChannel( 5, 0 );
  ReefAngel.PWM.SetChannel( 5, PWMSlope(21,0,13,0,0,MoonPhase() ,60,0) );
  //Mix Kalkwasser
static unsigned long Kalk_Mixing = 0;
static unsigned long stopTime = 0;
static byte prevWL=0;
if (ReefAngel.WaterLevel.GetLevel(1)>=100 && prevWL<100) {
  stopTime=now()+3600; // Get time one hour from now.
prevWL = ReefAngel.WaterLevel.GetLevel(1); // Store the water level
if (now() < stopTime) { ReefAngel.Relay.On(Kalkwasser); } else { ReefAngel.Relay.Off(Kalkwasser); }
  //AutoFeeder
static unsigned long autofeeding = 0;
if ((now()%SECS_PER_DAY==64800)) //if it is 6 pm
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-autofeeding>=60) && (now()-autofeeding<=61)) //if between 60 and 61 seconds has past
if ( autofeeding > 0 ) {
autofeeding = 0;
  // DeNitrate Routine
int DeNit_Offset=3600;
int DeNit_Repeat=21600;
int DeNit_Doser_Offset=1200;
int DeNit_Doser_Runtime=600;
int DeNit_Pump_Runtime=1200;
int DeNit_ATO_Offtime=1500;
// Pump comes on first
ReefAngel.Relay.Set(DeNit_Pump,(now()-DeNit_Offset)%DeNit_Repeat<DeNit_Pump_Runtime);  // Runs denitrator pump
// Doser comes on second
ReefAngel.Relay.Set(DeNit_Doser,((now()-DeNit_Offset)-DeNit_Doser_Offset)%DeNit_Repeat<DeNit_Doser_Runtime); // Runs denitrator doser
  // Disable ATO
if ( (now()-3600)%21600<DeNit_ATO_Offtime) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
  // Delay WL ATO after water change and DeNit_Dosing
  static time_t wcTimer=0;
  // First 10 minutes after WC disable ATO
  if (now()-wcTimer >= 0 && now()-wcTimer < 600)
    // Track Salinity low duration
    static unsigned long lastGoodSal;
    static boolean lowSalFlag;
    // Salinity is good, update counter
    if (ReefAngel.Params.Salinity>=335) lastGoodSal=now();
    // Counter hasn't been updating in 300 seconds..
    if (now()-lastGoodSal>300) {
      lowSalFlag=true; // Salinity is definitely below 33.5
      lowSalFlag=false; // Salinity back to normal
    // Disable ATO if lowSalFlag is true
    if (lowSalFlag) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
  // Disable ATO if ATO High IsActive()
static int rmode;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<3600) {
} else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Speed=30;
  ReefAngel.Portal( "Sacohen","S3tho31o" );
int x,y;
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,57, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,57, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,66,66, "WL 1:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel(1) );
//Salinity
  strcat(text,"  ");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,39,75,"Salinity:");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,99,75,text);
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
Just Error Compiling? Odd.i'll take a look tonight
Yeah. That's all it says on the bar.
So I got "Error Compiling" as well with the following info though in the box at the bottom..
/Users/lnevo/Documents/Arduino/libraries/ReefAngel/ReefAngel.cpp: In member function 'void ReefAngelClass::SetDCPumpChannels(byte, byte)':
/Users/lnevo/Documents/Arduino/libraries/ReefAngel/ReefAngel.cpp:2333: error: name lookup of 'a' changed for new ISO 'for' scoping
/Users/lnevo/Documents/Arduino/libraries/ReefAngel/ReefAngel.cpp:2322: error: using obsolete binding at 'a'
/Users/lnevo/Documents/Arduino/libraries/ReefAngel/ReefAngel.cpp:2333: error: expected primary-expression before ')' token
I think I hit that before and fixed it, maybe it forgot to get in the commit? Checking it now....
AlanM
Post by AlanM »
What are you two working on? You want one pump running ReefCrest while another runs Nutrient Transport? lol
Ok. Fixed it. Not sure why I was able to compile on my test code. Guess it would depend on what channels were used, I think in my I was just doing daylight/actinic.
Anyway, re-download the update at here
AlanM wrote:What are you two working on? You want one pump running ReefCrest while another runs Nutrient Transport? lol
No, just the ability to slow one of the pumps down if it's overpowered.
