I cannot access my controller from portal or the away profile in my phone. My home IP has not changed.
If I use the home profile it work fine.
What could be the issue?
WiFI stop work with away access
Re: WiFI stop work with away access
That's port forwarding or your ISP changed your ip address.
Check if your port forwarding is working correctly and also if the ip didn't change.
Use this tool with port 2000:
It needs to say open for you to be able to connect to your RA.
