Temp Probe connector
Posted: Fri Sep 13, 2013 2:35 pm
by ganjero
A cable in one of my Temp probe connectors came off. I dont know how because I havent touch anything in my controller for a long time, maybe it was someone else in the house. How difficult is to repair it? to get the cable back in?
Thanks'
Re: Temp Probe connector
Posted: Sat Sep 14, 2013 8:44 pm
by Piper
Can you post a pic? Is the crimp-on pin still on the end of the wire or do you just have bare copper on the end?
Posted: Mon Sep 16, 2013 8:25 am
by ganjero
I'll try to take a pic. It is the bare wire, the pin stayed in the plastic housing
Posted: Wed Sep 18, 2013 9:45 am
by Piper
It's easy to repair if you already have the crimp tool and spare pins. If you don't have the tool it'd be cheaper to order a new probe. I think the cheapest crimp tool I've found was around $15 and a new probe will run you $5-$10.
You could also try to pulling the pin out of the housing (use a straightened out paper clip or toothpick to help get it out) and solder the wire on.
~Charlie
Posted: Fri Sep 20, 2013 5:52 am
by ganjero
Thanks Piper, Roberto suggested the same. I will try to get it out and solder it.
