Android App question
Posted: Sat Sep 14, 2013 11:50 am
by cjrudy
So I just got a new phone and now have the android app which I love. One thing I haven't been able to figure out is how to adjust my DC pumps from the app or if I can.
Also wondering if there is any instructions on all the internal memory settings and how to use them ? I am currently adjusting all internal memory settings from the portal.
Re: Android App question
Posted: Sat Sep 14, 2013 5:03 pm
I'm not sure how the DC pumps are configured and setup, so I cannot give you an answer on how to control them from the android app. If they are run off the internal memory sections, then you can control them but otherwise I do not know.
To use the Internal Memory and control it, you simply need to open the Internal Memory section of the app (under the settings). Then you select the memory location from the drop down list. You can either Read (get the value stored) the location by clicking the Read Value button which queries the value from the controller or Write (stores the value) the value entered onto the controller. There will be a popup that says OK or ERR if the write was successful or not.
Posted: Sat Sep 14, 2013 5:28 pm
Curt they work just like the RF module but three different mem locations
Posted: Sat Sep 14, 2013 7:06 pm
by cjrudy
Thanks Curt,
Read/write...........duh, of course, I cant believe I even asked that question considering I'm in IT, I should have figured that out.
The only thing I don't see is the ability to control my DC Jebao power heads ?
Posted: Mon Sep 16, 2013 7:03 pm
cjrudy wrote:Thanks Curt,
Hmmmm... i may not have the dc pump memory locations added into the list yet. the dc pump class is relatively new and i have not followed it too closely which means I have not added it to the list of built in locations. my best suggestion for now is to look at the globals.h file to locate the dc pump memory locations and enter the location manually to read/write. you will have to use the custom location and enter the values in each time you want to adjust them for now. yeah, it's a little cumbersome and a pain but that's just how it has to be for now until I get a chance to get things updated properly.
Sent from my Nexus 7
Posted: Tue Sep 17, 2013 3:57 am
by cjrudy
The Jebao wavemakers are definitely becoming popular and with Roberto's Jebao Cable its so easy to hook them up to the controller. I'm currently using the portal to adjust the pumps so its not a big deal.
Thanks again Curt, love the app regardless.
Posted: Mon Oct 14, 2013 9:41 am
by rossbryant1956
as to reading these values when tested in the app, how do I read them...for example in my delayed start time, location 920, I have the number 7. What does this mean?
Thx
Posted: Mon Oct 14, 2013 12:06 pm
Thats not the correct location. That might have been the old locations, now they go from 200-350ish
Look in Globals\Globals.h for all the locations. Search for VarStart
Posted: Mon Oct 14, 2013 12:07 pm
But 7 would be 7 minutes
Posted: Mon Oct 14, 2013 6:42 pm
by rossbryant1956
whats the difference between Mem_B_* and Mem_I_* ?
Posted: Mon Oct 14, 2013 7:09 pm
rossbryant1956 wrote:whats the difference between Mem_B_* and Mem_I_* ?
Mem_B_* uses 1 storage location for the value (byte). The values can be from 0-255.
Mem_I_* uses 2 storage locations for the value (int). The values can be from 0-32768.
Since memory is limited on the controller, we only want to use the least amount of storage space and not waste anything.
