Relay Expansion Module
Posted: Sat Oct 22, 2011 2:37 pm
Got my extra relay box w/ expansion module in recently and I can't seem to get any of the ports turned on.
1. Jumpers are in the head unit
2. Switch settings are all in the off position (ID#1)
3. Green power light is on
4. Loaded code to turn all the ports on
5. Ran I2C Scanner as well
PDE Code:
I2C Results:
Thanks in advance!
PDE Code:
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#define Daylight 1
#define AutoTopOff 2
//#define Chiller 2
#define Heater 3
#define Return 4
#define WavemakerL 5
#define WavemakerR 6
#define LEDs 7
#define Refugium 8
randomSeed(analogRead(0)); //wm stuff
ReefAngel.FeedingModePorts = B00001000;
ReefAngel.WaterChangePorts = B00000000;
ReefAngel.OverheatShutoffPorts = B00000101;
ReefAngel.LightsOnPorts = B00000001;
ReefAngel.Relay.On(Return); //port 4
//relay expansion testing
ReefAngel.Relay.On(11); //testing ID1
ReefAngel.Relay.On(12);
ReefAngel.Relay.On(13);
ReefAngel.Relay.On(14);
ReefAngel.Relay.On(15);
ReefAngel.Relay.On(16);
ReefAngel.Relay.On(17);
ReefAngel.Relay.On(18);
/*ReefAngel.Relay.On(21); //testing ID2
ReefAngel.Relay.On(22);
ReefAngel.Relay.On(23);
ReefAngel.Relay.On(25);
ReefAngel.Relay.On(26);
ReefAngel.Relay.On(27);
ReefAngel.Relay.On(28);*/
//wm stuff
ReefAngel.Timer[1].SetInterval(random(15,35));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(WavemakerL);
// ReefAngel.StandardFan(Chiller,775,783); Removed for ATO function
ReefAngel.StandardHeater(Heater,768,771);
ReefAngel.StandardLights(Daylight,9,0,20,30); //Daylight schedule 9:00am - 8:30pm
ReefAngel.StandardLights(Refugium,21,0,9,0); //Refugium schedule 9:00pm - 9:00am
ReefAngel.StandardLights(LEDs,8,30,22,0); //LED schedule 8:30am - 10:00pm
ATOFailSafe(AutoTopOff); //ATO Stuff
//Wavemaker stuff
ReefAngel.Timer[1].SetInterval(random(15,30));
ReefAngel.Relay.Toggle(WavemakerL); //port 5
ReefAngel.Relay.Toggle(WavemakerR); //port 6
void ATOFailSafe(byte ATO) //changed port to ATO
// Check for the low switch
If the Low switch is active, meaning the float is opposite the end with the two wires,
we are empty so we should turn on the pump. Otherwise, we are full, so turn off the port.
if ( ReefAngel.LowATO.IsActive() )
ReefAngel.LowATO.StartTopping();
ReefAngel.Relay.On(ATO);
ReefAngel.LowATO.StopTopping();
ReefAngel.Relay.Off(ATO);
if ( ReefAngel.LowATO.IsTopping() && ! ReefAngel.HighATO.IsActive() )
// We have a problem
The pump is running and topping but the low switch isn't shutting off the port.
We must shutoff the port ourself.
// Trigger some sort of alert, maybe an email or text message
We did not indicate that the port is not topping anymore, we could do that manually
OR we could not do it and replace the switch and have the controller do it for us.
It's completely up to the user.
At this point, it shouldn't matter because there is a problem with the switch and that
needs to be addressed.
I2CScanner ready!
starting scanning of I2C bus from 1 to 128...
addr: 1 addr: 2 addr: 3 addr: 4
addr: 5 addr: 6 addr: 7 addr: 8
addr: 9 addr: 10 addr: 11 addr: 12
addr: 13 addr: 14 addr: 15 addr: 16
addr: 17 addr: 18 addr: 19 addr: 20
addr: 21 addr: 22 addr: 23 addr: 24
addr: 25 addr: 26 addr: 27 addr: 28
addr: 29 addr: 30 addr: 31 addr: 32 found!
addr: 33 addr: 34 addr: 35 addr: 36
addr: 37 addr: 38 addr: 39 addr: 40
addr: 41 addr: 42 addr: 43 addr: 44
addr: 45 addr: 46 addr: 47 addr: 48
addr: 49 addr: 50 addr: 51 addr: 52
addr: 53 addr: 54 addr: 55 addr: 56 found!
addr: 57 addr: 58 addr: 59 addr: 60
addr: 61 addr: 62 addr: 63 addr: 64
addr: 65 addr: 66 addr: 67 addr: 68
addr: 69 addr: 70 addr: 71 addr: 72
addr: 73 addr: 74 addr: 75 addr: 76
addr: 77 addr: 78 addr: 79 addr: 80 found!
addr: 81 addr: 82 addr: 83 addr: 84 found!
addr: 85 addr: 86 addr: 87 addr: 88
addr: 89 addr: 90 addr: 91 addr: 92
addr: 93 addr: 94 addr: 95 addr: 96
addr: 97 addr: 98 addr: 99 addr: 100
addr: 101 addr: 102 addr: 103 addr: 104 found!
addr: 105 addr: 106 addr: 107 addr: 108
addr: 109 addr: 110 addr: 111 addr: 112
addr: 113 addr: 114 addr: 115 addr: 116
addr: 117 addr: 118 addr: 119 addr: 120
addr: 121 addr: 122 addr: 123 addr: 124
addr: 125 addr: 126 addr: 127 addr: 128
done
