Feeding mode and Jeboa
Posted: Mon Sep 16, 2013 3:42 pm
In another post Inevo wrote
I have been using the ATOPinLow port and memory settings via the Portal to control my Jeboa WP25 for some time, but have found that during feeding mode the pump stops. What I would like is for it to continue running at a lower speed.
I have tried adding ReefAngel.DCPump.FeedingSpeed=10; to my code, but the pump still did not operate during the feed mode. I have tried a number of values up to 50 with the same result.
I am not sure if the ReefAngel.DCPump.FeedingSpeed should or will work with the ATOPinLow port or not. if it should do, then do I have the command in the right place in my code.
Any suggestions please.
My INO
If you want you can define the speed for Water Change and Feeding Modes...
My INO
// Created using Wizard 14/09/2013
// DC pump set to use ATOPinLow
InternalMemory.LCDID_write(0); // new LCD screen
ReefAngel.FeedingModePorts = Port1Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit;
ReefAngel.DCPump.FeedingSpeed=50;
// ReefAngel.StandardATO( Port2 );
ReefAngel.DosingPumpRepeat1( Port7 );
ReefAngel.DosingPumpRepeat2( Port8 );
ReefAngel.DCPump.LowATOChannel = Sync ; // Jebo connected to AtoPINLow
// Waterlevel code changed 20/04/13 to stop quick cycle of ATO pump
byte l = ReefAngel.WaterLevel.GetLevel();
if (l>85) ReefAngel.Relay.Off(Port2);
if (l<82 && l>0) ReefAngel.Relay.On(Port2);
if (now()%20<10)
// Delay turning Skimmer back on
ReefAngel.Relay.DelayedOn( Port1,60 );
// Activate Watch Dog Timer at 6am and 6pm
if ((now()%86400)==21600) delay(1000);
if ((now()%86400)==43200) delay(1000);
// Wavemaker not available 9 pm to 10 am
if ( (hour() >= 20) || (hour() <= 9) )
ReefAngel.DCPump.Mode==Custom;
ReefAngel.Portal( "sebyte" );
int x,y;
// Parameters
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
// Date and Time
