In addition to buying another relay box is there anything else I need to purchase and how do I hook this all up?
Adding a 2nd relay box how-to
- lnevo
Re: Adding a 2nd relay box how-to
Do you have any expansion modules already? (Ie the usb port on your current relay box)
If so you'll need an expansion hub. Otherwise you are good to go.
- Sacohen
It's simple to hook up.
There is an manual online.
http://www.reefangel.com/files/Relay%20 ... _1.3.0.pdf
