Time Travelling Reef Angel
Posted: Wed Sep 25, 2013 1:28 pm
So, I'm having this weird thing happening with me RA+. The other night I uploaded my code that I wrote (based off the RAgen code with a few changes) and within a few hours the RA went crazy. The date was saying it was 03/07/43 and a time it wasn't 08:16:35 PM at 6:10 in the morning (I noted that the seconds weren't always going up in 1's but still a second apart. eg 34, 35, 36, 38, 39, 41). The status light on the RA+ was also blinking a quick blink every second or so.
Does anyone know whats happening? when I reboot m controller by unplugging it and plugging it back in, none of the relays will then change from off until i unplug the USB cable from the relay box to the expansion hub and plug it back in.
Any help would be awesome.
P.S. Today I'm running it on RAGen code with NO modifications to see how it copes
#include <WiFiAlert.h>
// Custom Menu
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Lights On";
prog_char menu2_label[] PROGMEM = "Feeding Mode";
prog_char menu3_label[] PROGMEM = "Water Change";
prog_char menu4_label[] PROGMEM = "ATO Clear";
prog_char menu5_label[] PROGMEM = "Overheat Clear";
prog_char menu6_label[] PROGMEM = "PH Calibration";
prog_char menu7_label[] PROGMEM = "Sal Calibration";
prog_char menu8_label[] PROGMEM = "ORP Calibration";
prog_char menu9_label[] PROGMEM = "Date / Time";
menu4_label, menu5_label, menu6_label,
menu7_label, menu8_label, menu9_label
// Define Relay Ports by Name
#define Return 1
#define WaveMakerLeft 2
#define WaveMakerRight 3
#define LED_WhiteBlue 4
#define LED_Supplemental 5
#define LED_Moonlights 6
#define SkimmerPump 7
#define SkimmerVenturi 8
#define Heater1 Box1_Port1
#define Heater2 Box1_Port2
#define Chiller Box1_Port3
#define ChillerPump Box1_Port4
#define SumpLight Box1_Port5
#define Ozone Box1_Port6
#define ATO Box1_Port7
#define Unused Box1_Port8
//Define Custom Memory Locations
#define CMem_B_Delay_Ozone 100
#define CMem_B_Delay_Skimmer 101
#define CMem_B_Delay_Chiller 102
#define CMem_I_OrpMin 103
#define CMem_I_OrpMax 104
#define CMem_B_LightsEnabled 105
#define CMem_B_ResetMemory 199
void init_memory()
InternalMemory.write(CMem_B_Delay_Ozone,10);
InternalMemory.write(CMem_B_Delay_Skimmer,5);
InternalMemory.write(CMem_B_Delay_Chiller,1);
InternalMemory.write_int(CMem_I_OrpMin,400);
InternalMemory.write_int(CMem_I_OrpMax,420);
InternalMemory.write(CMem_B_LightsEnabled,false);
InternalMemory.write(CMem_B_ResetMemory,true);
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port7Bit;
ReefAngel.FeedingModePortsE[0] = Port4Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit;
ReefAngel.LightsOnPorts = Port4Bit | Port5Bit;
ReefAngel.LightsOnPortsE[0] = Port5Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Return );
ReefAngel.Relay.On( WaveMakerLeft );
ReefAngel.Relay.On( WaveMakerRight );
ReefAngel.Relay.On( SkimmerVenturi );
ReefAngel.Relay.On( Chiller );
//RA has been restarted. Set lights enabled memory to off
ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize Menu
if (InternalMemory.read(CMem_B_ResetMemory))
init_memory();
InternalMemory.write(CMem_B_ResetMemory,false);
//Initialise Relays
ReefAngel.MoonLights( LED_Moonlights );
ReefAngel.MoonLights( SumpLight );
ReefAngel.DayLights( LED_WhiteBlue );
ReefAngel.DayLights( LED_Supplemental );
ReefAngel.StandardHeater( Heater1 );
ReefAngel.StandardHeater( Heater2 );
ReefAngel.StandardFan( ChillerPump );
ReefAngel.SingleATOLow( ATO );
ReefAngel.Relay.DelayedOn( Ozone, InternalMemory.read(CMem_B_Delay_Ozone));
ReefAngel.Relay.DelayedOn( SkimmerPump, InternalMemory.read(CMem_B_Delay_Skimmer));
// ReefAngel.Relay.DelayedOn( Chiller, InternalMemory.read(CMem_B_Delay_Chiller));
//SetPWM as normal if Lights Mode Off
if(!InternalMemory.read(CMem_B_LightsEnabled))
ReefAngel.PWM.Channel0PWMParabola();
ReefAngel.PWM.Channel1PWMParabola();
ReefAngel.PWM.Channel2PWMParabola();
ReefAngel.PWM.Channel3PWMParabola();
ReefAngel.PWM.SetChannel( 4, MoonPhase() );
ReefAngel.PWM.SetChannel( 5, MoonPhase() );
ReefAngel.PWM.SetChannel(0,80);
ReefAngel.PWM.SetChannel(1,100);
ReefAngel.PWM.SetChannel(2,100);
ReefAngel.PWM.SetChannel(3,100);
OrpControl();
ReefAngel.Portal( "egadgetjnr" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// I/O Expansion
byte bkcolor;
x = 14;
y = 32;
ReefAngel.LCD.DrawCircleOutline( x+(a*20),y,4,COLOR_MEDIUMORCHID );
if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE;
else bkcolor=COLOR_GRAY;
ReefAngel.LCD.FillCircle( x+(a*20),y,2,bkcolor );
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,16,69, "SAL:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.Salinity,COLOR_DARKKHAKI,40,69, 10 );
// ORP
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,82,69, "ORP:" );
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,106,69, ReefAngel.Params.ORP );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,80, "PHE:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,80, 100 );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 90, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 103, TempRelay );
// Date and Time
void OrpControl()
int iOrpMax = InternalMemory.read(CMem_I_OrpMax);
int iOrpMin = InternalMemory.read(CMem_I_OrpMin);
int iCurrentOrp = ReefAngel.Params.ORP;
byte bOzoneDelay = InternalMemory.read(CMem_B_Delay_Ozone);
static boolean bOrpOn;
static WiFiAlert waOrpAlert;
if(iCurrentOrp >= iOrpMax)
//Turn off Orp Relay
//Serial.println("Orp Is Off");
ReefAngel.Relay.Off(Ozone);
//Send alert Orp is Off
waOrpAlert.Send("Ozone+is+off!+Max+Ozone");
bOrpOn = false;
//write to mem when orp off
if(!bOrpOn && iCurrentOrp <= iOrpMin )
//Trigger ORP Relay
//Serial.println("Orp Is On");
//Serial.print(ReefAngel.Relay.Status(Ozone));
ReefAngel.Relay.DelayedOn(Ozone,bOzoneDelay);
waOrpAlert.Send("Ozone+is+on.");
bOrpOn = true;
void Overheat()
//Enter code for overheat
//Send wifi alert
//Menu Code
/*prog_char menu1_label[] PROGMEM = "Lights On";
prog_char menu9_label[] PROGMEM = "Date / Time";*/
void MenuEntry1()
//Turn All Lights On
//Turn All Lights Relays On (except moons)
ReefAngel.Relay.Override(LED_WhiteBlue,1);
ReefAngel.Relay.Override(LED_Supplemental,1);
ReefAngel.Relay.Override(SumpLight,1);
InternalMemory.write(CMem_B_LightsEnabled,true);
//Set PWM to max
//Might not need to, done in loop
//Set Lights to default
ReefAngel.StandardLights(LED_WhiteBlue);
ReefAngel.StandardLights(LED_Supplemental);
ReefAngel.MoonLights(SumpLight);
//Set PWM to normal
void MenuEntry2()
//Feeding Mode
ReefAngel.FeedingModeStart();
void MenuEntry3()
//Water Change
void MenuEntry4()
//ATO Clear
ReefAngel.ATOClear();
void MenuEntry5()
//Overheat Clear
ReefAngel.OverheatClear();
void MenuEntry6()
//PH Calibration
ReefAngel.SetupCalibratePHExp();
void MenuEntry7()
//Sal Calibration
//ReefAngel.SetupCalibrateSalinity();
//ReefAngel.DisplayedMenu = ALT_SCREEN_MODE;
void MenuEntry8()
//ORP Calibration
void MenuEntry9()
//Date/Time
ReefAngel.SetupDateTime();
