Hey guys,
Do it need the plus model? I think the answer is yes.
I want to control the following:
2 WP25's
Skimmer
Return
Heater
Sump light
ATO
Fan
Temp prob
PH prob
My LED's will not be on the RA as the evergrow lights can not be controlled by RA
I am looking for standard control for everything but the WP25's I would like to get a little creative in the programming of the those. switching modes multiple time throughout the day, sync and anit-sync changes. feed mode that goes into a nutrient expert mode for 15 min after feeding and then back to normal.
Also want to add Wifi. Not sure if that is additional memory
PWM or PWM plus
- lnevo
Re: PWM or PWM plus
PlusSiebo wrote:I would like to get a little creative in the programming
Siebo
Re: PWM or PWM plus
What functionality comes standard on the non plus model for jeabo pumps, is it similar programming to a vortec pump. Can you sync and anti sync with no additional programming?
- lnevo
Re: PWM or PWM plus
Its not an issue of functionality but memory. The standard will work to control Jaebo pumps with all the ease of the vortech, but you will have very little room to do any customization. Plus is the same otherwise except it comes with a usb power cable
