I think there was an error in the if statement.
ReefAngel.WaterChangePorts = Port1Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit;
InternalMemory.OverheatTemp_write( 840 );
ReefAngel.DCPump.FeedingSpeed=5;
ReefAngel.StandardHeater( Port1,790,808 );
ReefAngel.StandardFan( Port2,810,820 );
ReefAngel.DosingPumpRepeat( Port3,10,120,1 );
ReefAngel.DosingPumpRepeat( Port4,3,120,1 );
ReefAngel.StandardLights( Port7,12,0,23,30 );
ReefAngel.StandardLights( Port8,12,0,23,30 );
ReefAngel.PWM.SetChannel( 0, PWMParabola(10,30,22,45,0,85,0) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(10,30,22,30,0,85,0) );
ReefAngel.PWM.SetChannel( 2, PWMParabola(11,0,22,15,0,85,0) );
ReefAngel.PWM.SetChannel( 3, PWMParabola(11,30,21,50,0,90,0) );
ReefAngel.DCPump.ExpansionChannel[0] = None;
// Schedule for WP40 #1 and #2
if (hour()<8) // WP40 #1 and #2 at 30% from 12am-8am
ReefAngel.DCPump.SetMode( Lagoon,30,10 );
if (hour()>=8 && hour()<11) // WP40 #1 and #2 at 50% in Lagoon mode from 8am-11am
ReefAngel.DCPump.SetMode( Lagoon,50,10 );
if (hour()>=11 && hour()<20) // WP40 #1 and #2 at 60% in Reef Crest mode from 11am-10pm
ReefAngel.DCPump.SetMode( ReefCrest,65,20 );
if (hour()>=20 && hour()<21) // WP40 #1 and #2 at 50% in Lagoon mode from 10pm-11pm
if (hour()>=21) // WP40 #1 and #2 at 30% 11pm-12am
// Run Nutrient Transport Mode after Feeding Mode completes
static unsigned long feeding;
feeding = now();
ReefAngel.DCPump.SetMode( Constant,10,10 ); // Set WP40 #1 and #2 to 10% speed
if (now()-feeding<=30) // Next 30 seconds are in Nutrient Transport Mode(for testing)
ReefAngel.DCPump.SetMode( NutrientTransport,70,30 ); // Set WP40 #1 and #2 to 70% speed with 30ms pulse in Nutirnet Transport Mode
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,76, "PHE:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,76, 100 );
// Main Relay Box
// Date and Time
