Can I code my 2 jebao wp40's to run at different speeds?
Posted: Thu Oct 03, 2013 1:18 pm
by DavidinGA
I have two Jebao WP40 wavemakers and it seems like one of them has lost noticeable power and so I was wondering if I could code them to have the weaker one run at higher percentages to make up for the power loss...???
    ReefAngel.StandardHeater( Port1,795,800 );
    ReefAngel.StandardHeater( Port2,793,800 );
    ReefAngel.StandardLights( Port3,1,0,24,0 );   ////gfo
    ReefAngel.StandardLights( Port4,11,0,21,0 );  ////UV
    ReefAngel.DosingPumpRepeat( Port6,0,240,600 ); /////ato powerhead 240min = 4hrs
    ReefAngel.DosingPumpRepeat( Port7,0,360,20 );  /////alk 360min = 6hrs
    ReefAngel.DosingPumpRepeat( Port8,0,420,35 );  ////cal 420min = 7hrs
    ReefAngel.DCPump.SetMode( LongPulse,40,10 );
    if (hour()<8)
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
else if (hour()>=8 && hour()<10)
ReefAngel.DCPump.SetMode( ShortPulse,80,20 );
else if (hour()>=10 && hour()<12)
ReefAngel.DCPump.SetMode( LongPulse,65,5 );
else if (hour()>=12 && hour()<14)
ReefAngel.DCPump.SetMode( ShortPulse,70,15);
else if (hour()>=14 && hour()<16)
ReefAngel.DCPump.SetMode( ReefCrest,50,20 );
else if (hour()>=16 && hour()<22)
ReefAngel.DCPump.SetMode( ShortPulse,75,20 );
    ReefAngel.Portal( "davidinga" );
    int x,y;
    // Parameters
    // pH Expansion
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,66, "PHE:" );
    ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,66, 100 );
    // Main Relay Box
    // Date and Time
Re: Can I code my 2 jebao wp40's to run at different speeds?
Posted: Thu Oct 03, 2013 1:25 pm
by ReeferBee
 if (hour()<8)
The values 80, 65, 70, 50, and 75 are the speeds. Adjust that number on the modes accordingly
Posted: Thu Oct 03, 2013 1:29 pm
by ReeferBee
I'm on the older library, my code looks different. I'm sure someone else can chime in and help you.
Posted: Thu Oct 03, 2013 1:39 pm
by DavidinGA
ReeferBee wrote:
 if (hour()<8)
Right but I only want to increase the speed of one of the pumps; not both of them.
Posted: Thu Oct 03, 2013 3:58 pm
by Sacohen
Take the pump apart and clean the impeller shaft and inside of the housing it will run like new once you do that.
Just twist the top cover counter clockwise and it pops right off.
Posted: Thu Oct 03, 2013 4:39 pm
At some point i will add a way to add an AntiSync speed offset. So there is more control. Especially when you may have different types of pumps.
Posted: Thu Oct 03, 2013 4:46 pm
by DavidinGA
Sacohen wrote:Take the pump apart and clean the impeller shaft and inside of the housing it will run like new once you do that.
I actually did do that. It improves the performance a little but the new WP40 still outperforms this older one (6 months old now).
Posted: Fri Oct 04, 2013 5:27 am
by Sacohen
In a couple of months the new one will probably slow down a bit too and be somewhat equal to the old one.
Posted: Sat Oct 05, 2013 1:31 pm
by DavidinGA
So there really isn't a way to code them for separate speed levels???
Sent from my SCH-I605 using Tapatalk 4
Posted: Sat Oct 05, 2013 2:00 pm
by Sacohen
Not right now if you are using the DCPump Class.
If you want to use the older method then yes it is possible.
I had it set up on my WP-40 and WP-25.
ReefAngel.PWM.SetDaylight( LongPulseMode(45,70,10,true));
ReefAngel.PWM.SetActinic( LongPulseMode(65,70,10,true));
PulseMinSpeed - % for minimal speed
PulseMaxSpeed - % for maximum speed
PulseDuration - Duration (seconds) in which each pulse will be held. The pump will stay at minimal speed for PulseDuration and will stay at maximum speed for PulseDuration.
PulseSync - true if you want to sync pumps to same cycle. one false and one true if you want to anti-sync pumps.
Here is a link to the different pump modes and their settings.
http://forum.reefangel.com/viewtopic.php?f=7&t=2844
