RA as a ph controller?
Posted: Thu Oct 03, 2013 6:43 pm
by kraken
Is there a way to use the RA as a ph controller for the deltec PF501 calcium reactor?
Re: RA as a ph controller?
Posted: Thu Oct 03, 2013 7:46 pm
Yeah i forget the function off hand but its like the heater function.but you set a low and a high ph to control your solenoid relay.
Posted: Thu Oct 03, 2013 10:31 pm
by egadgetjnr
Someone correct me if I'm wrong, but I think it might be:
ReefAngel.PHControl(byte PHControlRelay);
Or
ReedAngel.PHControl(byte PHControlRelay, int LowPH, int HighPH);
Posted: Fri Oct 04, 2013 12:22 am
by kraken
so basically use one of the ports and switch on/off the power to the solenoid while reaching a certain ph range?
that being said, I would lose the ph monitoring of the main tank if I deploy the ph probe into monitoring the reactor.
Posted: Fri Oct 04, 2013 1:00 am
by egadgetjnr
You could always get a PH expansion module. Then you could have both
Posted: Fri Oct 04, 2013 1:55 am
by kraken
I already have a salinity expansion, so if I were to add another ph expansion meant I would have to get the expansion hub also, am I correct?
Posted: Fri Oct 04, 2013 3:20 am
by egadgetjnr
Yep.
![Smile :)](./images/smilies/icon_e_smile.gif)
Posted: Fri Oct 04, 2013 4:26 am
You could also control the solenoid based on the ph of the tank rather than the ph of the effluent. At least till you get the hub and expansion.
Posted: Sat Oct 05, 2013 10:12 pm
by kraken
many thanks guys
