Multiple water level module status
Posted: Thu Oct 10, 2013 9:28 am
by Smotz
Any updates ?
Re: Multiple water level module status
Posted: Thu Oct 10, 2013 6:37 pm
I've got a couple, but the libraries are not finalized yet.
The calibration code I have isn't working right.
Posted: Thu Oct 10, 2013 6:55 pm
by Smotz
let me know. Going on vacation soon and will need to set up the ATO
Posted: Fri Oct 11, 2013 1:13 pm
by Piper
rimai wrote:I've got a couple, but the libraries are not finalized yet.
I'll post my modified code after I get home tonight. It calibrates all 5 ports (single at port 0, and the multi on ports 1 - 4) and seems to be working for me. I'm only using port 1 at the moment and it's calibrating and reading correctly.
Posted: Fri Oct 11, 2013 7:42 pm
by Piper
Here's what I used:
#ifdef WATERLEVELEXPANSION
void ReefAngelClass::SetupCalibrateWaterLevel()
	bool bOKSel = false;
	bool bSave = false;
	bool bDone = false;
	bool bDrawButtons = true;
	unsigned int iO[10] = {0,0,0,0,0,0,0,0,0,0};
	unsigned int iCal[2] = {0,100};
	byte offset = 65;
	// draw labels
	ClearScreen(DefaultBGColor);
	for (int b=0;b<10;b++)
		if (b==10 && !bSave) break;
		bOKSel=false;
		bSave=false;
		bDone = false;
		LCD.DrawText(DefaultFGColor, DefaultBGColor, MENU_START_COL, MENU_START_ROW, "Calibrate Water Level");
		char port[10] = "Port: ";
		itoa(b/2,port,10);
		LCD.DrawText(DefaultFGColor, DefaultBGColor, MENU_START_COL, MENU_START_ROW+16, port);
		char text[10] = "";
		itoa(iCal[b%2],text,10);
		strcat(text , " %  ");
		LCD.DrawText(DefaultFGColor, DefaultBGColor, MENU_START_COL, MENU_START_ROW*5, text);
		do
#if defined WDT || defined WDT_FORCE
			wdt_reset();
#endif  // defined WDT || defined WDT_FORCE
			iO[b]=0;
			for (int a=0;a<15;a++) {
				iO[b] += WaterLevel.Read(b/2);
			iO[b]/=15;
			LCD.DrawCalibrate(iO[b], MENU_START_COL + offset, MENU_START_ROW*5);
			if (  bDrawButtons )
				if ( bOKSel )
					LCD.DrawOK(true);
					LCD.DrawCancel(false);
					LCD.DrawOK(false);
					LCD.DrawCancel(true);
				bDrawButtons = false;
			if ( Joystick.IsUp() || Joystick.IsDown() || Joystick.IsRight() || Joystick.IsLeft() )
				// toggle the selection
				bOKSel = !bOKSel;
			if ( Joystick.IsButtonPressed() )
				bDone = true;
				if ( bOKSel )
					bSave = true;
		} while ( ! bDone );
	if ( bSave )
		// save WaterLevelMin & WaterLevelMax to memory
		InternalMemory.WaterLevelMin_write(iO[0]);
		InternalMemory.WaterLevelMax_write(iO[1]);
		InternalMemory.WaterLevel1Min_write(iO[2]);
		InternalMemory.WaterLevel1Max_write(iO[3]);
		InternalMemory.WaterLevel2Min_write(iO[4]);
		InternalMemory.WaterLevel2Max_write(iO[5]);
		InternalMemory.WaterLevel3Min_write(iO[6]);
		InternalMemory.WaterLevel3Max_write(iO[7]);
		InternalMemory.WaterLevel4Min_write(iO[8]);
		InternalMemory.WaterLevel4Max_write(iO[9]);
#endif  // WATERLEVELEXPANSION
Posted: Thu Jan 02, 2014 7:07 am
by phrusher
Any updates? Is it possible to run two single modules together?
Posted: Thu Jan 02, 2014 9:14 am
These module is available in the web store :)
It's a 4 port module.
Posted: Thu Jan 02, 2014 10:16 am
by phrusher
I have one single module and I just placed an order for an additional single module before seeing this thread :/
Sent from my Nexus 5 using Tapatalk
